New Topic New Reply
Author: Subject: IRS mods to book chassis PDF
Mix
posted on 21/5/05 at 07:53 AM Reply With Quote
In response to a request in the Avon section, I've converted a drawing showing the method I'm using to fit IRS to a book chasis into PDF format.
Be gentle
Mick
Mix
posted on 21/5/05 at 03:07 PM Reply With Quote
Wow!!
70 views and 70 downloads.
I'd appreciate comment and constructive criticism, nothing is set in stone as yet.
Mick
morf1
posted on 21/5/05 at 04:25 PM Reply With Quote
looks good but at the bottom of the chassis is flat rather than on a rake cant this be changed?? and do you have the measurements for all this
Mix
posted on 4/6/05 at 08:37 AM Reply With Quote
Morf
Why would you want the base of the chassis to rise at the rear? I would think the IRS loads are transmitted more efficiently through a flat construction. (The IRS theory gets more complex with angled wishbone mounts aswell).
Mick
Mix
posted on 14/10/05 at 06:42 AM Reply With Quote
For those who might want a bit of inspiration I've ressurected this thread.
I have drawings of all the components except the upper bones which have still to be finalised.
This design is untested but appears to work on 'paper'
Drawing is to scale
Mick
tiger builder
posted on 14/10/05 at 06:56 AM Reply With Quote
have you got any other drawings? for the wish bones etc, with measurments? Please.
907
posted on 14/10/05 at 07:48 AM Reply With Quote
Well done Mick.
Although we have aproached diagonal bracing differently, your wish bone size and mounting positions look very similar to mine.
I wish I could draw like you. Never could get the hang of cad and the like.
Is Morf refering to the chassis bottom rising before or after the rearmost w/b mount cross member?
The rear of mine goes up at the back in the fuel tank area, but like you say, keep it simple for the bone mounts.
Paul G
p.s. my sig seems appropriate for this thread
Mix
posted on 14/10/05 at 08:59 AM Reply With Quote
I would be willing to post more drawings however my trial version drawing to PDF converter has expired, can anyone point me in the direction of a good preferably free one?
Cheers Mick
posted on 14/10/05 at 09:43 AM Reply With Quote
It looks like you'll be cramped for tank space Mick. You could make the back a bit longer without any problems or you'll need a complicated (read expensive) shape for the fuel tank.
posted on 14/10/05 at 12:42 PM Reply With Quote
Has the roll center location/stability been calculated for this?
macintosh
posted on 14/10/05 at 01:08 PM Reply With Quote
What kind converter do you need?
There are some free ones, if they do not fit - please let me know.
http://www.primopdf.com/
http://www.pdf995.com/
New Topic New Reply
