Author: Subject: Pre SVA check - Have I covered everything?
Mark Allanson
posted on 29/5/05 at 06:50 PM Reply With Quote
Title says it all really. I have uploaded a few shots of the car in a sub folder of my archive.
Please spot the deliberate mistakes before the SVA tester does
http://www.locostbuilders.co.uk/photos.php?action=gal&user=Mark%20Allanson&folder=Pre%20SVA
Mark
rayward
posted on 29/5/05 at 07:10 PM Reply With Quote
Are your front flexi brake pipes OK, do they catch anything on either Lock?????
Ray
posted on 29/5/05 at 07:11 PM Reply With Quote
That looks very tidy, Mark!
The only thing that doesn't look right is the flexi brake pipe in the RHF view - it looks as though it's touching the tyre. It's probably a trick of the camera angle, but it's something to check. Turn the wheel full-lock each way and make sure that (a) the pipe doesn't touch or rub anything, and (b) it isn't stretched so much that it bends next to the fitting.
Apart from that - nothing obvious stands out!
Good luck,
bob
posted on 29/5/05 at 07:32 PM Reply With Quote
Looks very smooth to me mark,an excelent pre SVA example.
If it goes through on radius without a prob we should use the pics as a benchmark.
theconrodkid
posted on 29/5/05 at 08:13 PM Reply With Quote
the front wing stays look a little close to the tyres is my only comment,apart from that looks good and good luck
who cares who wins
pass the pork pies
Mark Allanson
posted on 29/5/05 at 08:25 PM Reply With Quote
My flexies clear everything nicely, the wing stays get no closer that 10mm (is that OK?). I need to get some sort of cover for the seatbelt upper attachments. The foglamp switch is the original sierra one, the symbol is the correct one, but is not illuminated, but there is a LED telltale about 2mm away from it. Rescued attachment Belt top mounts.JPG
billy
posted on 29/5/05 at 09:36 PM Reply With Quote
Hi m8, i can see 1 thing from your last pic that you will be picked up on and that you need to put covers on your seat belt harness bolts as thats wot he made me do best of luck
luego-lo-cost finished,vauxhall 16v 2.0,twin 45s de-dion rear set up
posted on 29/5/05 at 10:32 PM Reply With Quote
Put some clear mastic in the front indicator screw heads, it's the only unradiused edge left for them to pick up where the plastic is recessed for them.
mookaloid
posted on 30/5/05 at 06:40 AM Reply With Quote
Great looking car Mark!
I was pulled up on a sharp edge on the mirror mount (my screen wasn't fitted at the time
[Edited on 30/5/05 by mookaloid] Rescued attachment mirror.JPG
mookaloid
posted on 30/5/05 at 06:41 AM Reply With Quote
Consequently, you might want to have a look at these areas:
TPG
posted on 30/5/05 at 08:39 AM Reply With Quote
Front Indicators
They look familiar but are they more than 400mm in from the edge of the car?Remember the rs is wider.I fell over on this at sva.Good luck.
..Which was nice..
TPG
posted on 30/5/05 at 08:41 AM Reply With Quote
Oh.Rear reflectors.........Just seen them in the lights.
[Edited on 30/5/05 by TPG]
..Which was nice..
Marcus
posted on 30/5/05 at 09:33 AM Reply With Quote
How noisy is the car, if it's close to the limit, point those tailpipes out horizontally, you get far less reverberation if they point to the open air.
Good looking car, by the way.
Marcus
Marcus
Because kits are for girls!!
Mark Allanson
posted on 30/5/05 at 10:11 AM Reply With Quote
At 4000 rpm, you can still talk and be heard so I don't expect my dB's will be a problem. Thats due to the Passat rear box I am using
Hornet
posted on 30/5/05 at 03:26 PM Reply With Quote
Good luck Mark.... my SVA is Friday...
With regards to your photo's, the brake nut looks like it has sharp edges.... might be better to cover just in case... my cars like a marsh mallow just now.. if i hit someone, i'll sufficate them
Mark Allanson
posted on 30/5/05 at 06:00 PM Reply With Quote
What on earth do you use to cover brake nuts? This is starting to get silly!
My date is a week after yours
billy
posted on 30/5/05 at 07:58 PM Reply With Quote
Mark, i think it may help to let him find a few real obvious things to let him pick up on, hopefully he wont did too deep. also he looks out for unsuported wiring. cheers
Petemate
posted on 31/5/05 at 09:14 AM Reply With Quote
Hi Mark
That's one smart car you have there. I now want to tip my Robin Hood over a cliff....
Your build typifies what I have said all along; that you Locost boys do a fantastic job. Even starting with pre-built chassis, the standard of builds is very high. I've met a few on a local meet, and wish I'd have gone down this route. Well done & good luck for the SVA.
Petemate
barrie sharp
posted on 31/5/05 at 03:17 PM Reply With Quote
Looking good mark.nut covers on the top of the seatbelt fixings. The brake nuts look ok if the dome they use cannot reach them!. they like neat and tidy. have you got a boot box in yet?
Hows you self centreing and brakes? the others stuff is a easy fix.
we'll have a good look next thurs night.
have you got last minute nerves yet.
Barrie
the cars looking good" a blind man would be pleased to see it"
''stop press'' the blind mans seen it said "it felt ok"
Mark Allanson
posted on 31/5/05 at 06:33 PM Reply With Quote
have you got last minute nerves yet?.....
Just a bit
I have made a list of the last minute things....it's going to be a long weekend this week!
I am buying stuff to make modifications, steering rack gaitors for the mirrors, covers for the seat belts, a few more wiring tie backs........
Nervous?, Yes, confident? I dearn't
Jon Bradbury
posted on 1/6/05 at 08:39 AM Reply With Quote
Where did you get those mirrors from? They look fab.
Mark Allanson
posted on 1/6/05 at 07:00 PM Reply With Quote
Car builders solutions, I think they are Suzuki GXR mirrors, but it looks like they will not go through SVA without a touch of temporary modification. On the upside, I have complete rear vision without any blindspots.
zetec
posted on 2/6/05 at 09:31 PM Reply With Quote
Excellent job, well done and good luck.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
posted on 3/6/05 at 05:24 PM Reply With Quote
Mark , the mirrors look the same as the ones that I used, had to make a small adaptor to fit them to my screen pillars , tester just run his hands around them to test edges . Passed them without comment so yours should be O.K.
