Author: Subject: Cortina ball joint to Sierra hub
Mat-d-Rat
posted on 7/12/02 at 02:40 PM Reply With Quote
Is the bolt on the Cortina bottom ball joint (as sold by lolocost) the same size for the Sierra bottom hub hole? I'm building a Robin Hood Exmo, and am working on some new front suspension so not many of the hoodies know this. Also I'm trying to work out what size tubing I should use for the suspension (From reading 22x2.64mm)?
## # Mat # ##
Webmaster of www.RHOCaR.org
my eXmo - http://projectX.rhocar.org
charlie
posted on 7/12/02 at 03:10 PM Reply With Quote
The cortina balljoint does not fit into the sierra hub. You will need to have the bottom hole in the hub drilled to accept the cortina balljoint.
I think MK do this although Ive never been able to contact them. There is another place that does it but Ill have to look for the name. I think they supply the hubs drilled for about £55. Youll also need to get an insert for the top of the hub and I think your talking about £60 for that. Ill look for the name of that company and get back to you.
charlie
charlie
posted on 7/12/02 at 03:14 PM Reply With Quote
The email address is
Info@locostmechandise.7p.com
charlie
interestedparty
posted on 7/12/02 at 05:15 PM Reply With Quote
I understand that MK drill Sierra hubs to accommodate MAXI ball joints, not Cortina. I believe the bolt pattern (2, not 4) on the Maxi is different to the Cortina balljoint so you may well require new/modified wishbones (but I might well be wrong)
John
James
posted on 10/12/02 at 05:00 PM Reply With Quote
Do tapers come in standard sizes?
Is there a standard defined for tapered drill bits? Or is it done with angles or ratios (ie, breadth:length) or something?
Only reason I ask is I'd consider buying the right tool (bit) if I knew what size I needed.
What size is need for the Cortina/Maxi etc?
Thanks,
James
chrisg
posted on 10/12/02 at 07:19 PM Reply With Quote
I've seen it done with an old ball joint taper and grinding paste, takes forever BUT if you use a tapered drill use a depth stop cos if you go too far the uprights scrap!
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
Mat-d-Rat
posted on 14/12/02 at 01:08 PM Reply With Quote
Is there any bottom balljoint similar to the cortina style that fits the Sierra upright then?
## # Mat # ##
Mat-d-Rat
posted on 15/12/02 at 07:41 PM Reply With Quote
Has anyone used an early Astra Ball joint? These are suppose to be the same size?
## # Mat # ##
