Author: Subject: 2 pac drying times
tomm
posted on 24/6/05 at 11:48 PM Reply With Quote
2 pac drying times
Anybody know how to speed up the drying times for 2 pac paint? I've tried increasing the hardner from the specified 2/1+10% no difference still takes 6-7 hours even in this weeks temps.
jambojeef
posted on 24/6/05 at 11:52 PM Reply With Quote
Hello,
Are you spraying a bit too heavily?
I'm planning to use 2 Pack and according to what Ive read so far you should spray "dry" and the activator should react and give you the final finish?
You probably know all this already and itd be good to get some tips if it works since I cant speak from experience...
Geoff
Mark Allanson
posted on 24/6/05 at 11:53 PM Reply With Quote
Add 5ml of jet5 to the mix, and the unbaked drying (curing) will be about 30 mins
tomm
posted on 25/6/05 at 12:00 AM Reply With Quote
Thanks for the dry tip and the jet 5 what is that? I've only ever used celly, but the 2 pac finish is awesome by comparison, excepting that is for the flies!! but they can be polished out without too much hassle.
Providing I can get reasonable drying times It's 2 pac from now on
