<<  1    2  >>
New Topic New Reply
Author: Subject: Talking about corrosion - how come we don't stainless steel?
Damon Hill
posted on 29/6/05 at 04:39 PM Reply With Quote
i guess this has been discussed before, but can't find any threads...
andylancaster3000
posted on 29/6/05 at 04:45 PM Reply With Quote
Very hard, so hard to work, heavy and not as easy to weld.
posted on 29/6/05 at 04:49 PM Reply With Quote
Very abrasive (to cut) and dense - it's also very expensive! That discounts it from the locost theme!
andyps
posted on 29/6/05 at 04:59 PM Reply With Quote
At least one person on here is making / has made a stainless chassis. CAn't remember who though!
gazza285
posted on 29/6/05 at 05:07 PM Reply With Quote
Also stainless is prone to stress fractures.
907
posted on 29/6/05 at 05:13 PM Reply With Quote
Originally posted by Hellfire
it's very expensive! That discounts it from the locost theme!
If you take the price of mild steel, add the cost of, say, shot blasting & powder coating,
it's like my front room.... not a lot in it.
My chassis, with a floor, and w/b tube cost me about £200
Anyway, I hate painting
Paul G
JohnN
posted on 29/6/05 at 05:30 PM Reply With Quote
Previous thread for information...
Here
jonbeedle
posted on 29/6/05 at 08:19 PM Reply With Quote
907 (but he's a pro welder)!
"Everyone is entitled to an opinion however stupid!"
quattromike
posted on 30/6/05 at 06:47 AM Reply With Quote
I've also started making my chasis in stainless 316 grade . I'm not following the book design because i wanted to make it bigger so most of the strenghthening will be re-thought out anyway so i'm not all that worried about stress points yet. and i don't think it'll be heavier that mild steel because of the extra strength of stainless you can afford to go a tad lighter with the sections and you don't have any weight of the paint(or rust!) .
Bluemoon
posted on 30/6/05 at 09:26 AM Reply With Quote
Is'nt their a problem with electrochemical reactions of stainless steel and ali? This could cause the stainless to corrode, where pannels are pop rivited on. With steel it's the other way round, the pop rivites rust rather better situation I would suggest??
stevebubs
posted on 30/6/05 at 10:16 AM Reply With Quote
How structurally sound is it when MIGing Stainless?
I've migged up some small stainless items to good effect...using stainless wire (of course)
JonBowden
posted on 30/6/05 at 10:57 AM Reply With Quote
Anyone thought of a stainless monocoque as Robin Hood use.
I think there would be less of a problem with fatigue than with a spaceframe.
Jon
gazza285
posted on 30/6/05 at 10:59 AM Reply With Quote
"Is'nt their a problem with electrochemical reactions of stainless steel and ali? "
Stainless and ally together is a bad idea, but it is the ally which corrodes, and at quite a rate too.
quattromike
posted on 30/6/05 at 04:27 PM Reply With Quote
I think as long as they are not in direct contact with each other it would be ok. I'm thinking of using gasket sealer or somthing to that effect.
Mike
[Edited on 30/6/05 by quattromike]
Bluemoon
posted on 1/7/05 at 11:21 AM Reply With Quote
Bit tricky with Ali riviets? I guess you have to rely on keeping the water out rather than electrical insulation, e.g PU glue aound rivet holes before putting pannel on...
ned
posted on 1/7/05 at 11:29 AM Reply With Quote
simple solution with a stainless chassis would be to use stainless panels and stainless rivets surely?
Ned.
beware, I've got yellow skin
posted on 1/7/05 at 11:32 AM Reply With Quote
As formerly seen on the Isonblade - very striking to look at, too.
DJ
[Edited on 1/7/05 by David Jenkins]
kreb
posted on 1/7/05 at 01:38 PM Reply With Quote
Not to my knowledge. I do achitectural metalwork and we generally use SS as a safe go-between dissimilar metals. It does not seem to react to either ferous or non-ferous metals.
Perhaps there's something in the UK air?
https://www.supercars.net/blog/wp-content/uploads/2016/04/1966_FiatAbarth_1000SP1.jpg
posted on 1/7/05 at 01:53 PM Reply With Quote
A lot of water, usually!
gazza285
posted on 1/7/05 at 02:05 PM Reply With Quote
I work with achitectural and structural steel as well as foodstuff conveyors and stainless. We have always isolated stainless from both ferrous and non ferrous metals, including galvanised steelwork using polyeurethane washers and top hats in bolt holes and landing pads for mountings.
Galvanic reaction between stainless and alluminium/steel is very well documented in print as well as the web. Kreb, I hope I never have to walk under any of your work on a windy day.
quattromike
posted on 2/7/05 at 01:04 AM Reply With Quote
I think it's more of a problem between ali and mild steel than ali and stainless i've never heard of it being a major issue.
Is electrochemical only happen when surrounded by flowing water or somthing to that effect ? Thats why we fit alloy anodes to all steel frames for sub sea use, it eats the alloy first to prolong the life of the steel.
Mike
907
posted on 2/7/05 at 07:40 AM Reply With Quote
Hi All.
As I see it, the main problems with building in stainless are twofold.
Firstly the welding. It really has to be Tig, and welds really need to be backed with argon.
All the tee joints on my chassis have a 3 mm hole which allowed the argon to flow through while
it was being welded.
Tig welders, and a plentiful suply of gas doesn't come cheap.
Secondly, a chassis is not just 8 (ish) lengths of box section.
It's all the other bits that for most people would be a problem.
Small quanties of all sorts of round bar and plate are needed, seat belt mounts,
suspension brackets, rack mounts, fuel tank, steering column, the list is endless,
all need to be stainless as well.
I'm lucky, I work with this sort of stuff all the time. I can wander up to the gilly in
my lunch break and just chop a bit off.
Hand making every bit does mean it's a long build, four years so far,
but it will be finished one day, I hope.
Nice to see there's three of us now, or is there more?
Paul G
rocket
posted on 4/7/05 at 09:29 PM Reply With Quote
very bad idea
Not 316!!!!! stress cracks!!!!
Stainless is 1.5 times heavier you you need to use 22 gauge!
Rgds
Roger
Mike.
rocket
posted on 4/7/05 at 09:38 PM Reply With Quote
Stainless welding
It doesn't need backing up with argon unless you are planning to use it in a food factory or having a weld test. but make sure you clean all the welds after or it will rust. Stainless MIG no good on thin sheet TIG weld best.
Rgds
Roger
Originally posted by 907
Hi All.
Paul G
NS Dev
posted on 6/7/05 at 07:37 AM Reply With Quote
Hi All.
Paul G
Having seen 907's pics and various handiwork, I for one would love to see the finished car, as it will be a masterpiece!!
It does amuse me that stress cracking problems are mentioned in 316 stainless, but people have no qualms about using the cheapest mild steel erw that they can find, without thinking about the weld quality along the tube seams!!!! (which can be VERY poor!)
<<  1    2  >>
New Topic New Reply
