Author: Subject: ring too small?
wheelsinsteadofhooves
posted on 5/7/05 at 10:36 AM Reply With Quote
ring too small?
My part-built project came with a box marked "m16 caliper rebuild kit". all seems ok apart from the main ruber seals, which sit in the groove in the cylinder, are on the small side. they will stretch over the piston out of the caliper, and sort-of sit in the groove, but when in the groove its not possible to slide the piston in and vice versa its not possible to put the ring in the groove when stretched around the piston. do i indeed have the correct rebuild kit or is there a trick to combine piston/ring/cylinder groove?
thanks in advance.
JAG
posted on 5/7/05 at 10:46 AM Reply With Quote
The piston seal (it's a square section ring) should sit in the groove inside the caliper body and the piston should fit through it with very little stretching.
If you are having trouble then I would suggest you have the wrong seal.
When laid on the table, without stretching etc... it should be approx' 54mm in diameter.
Justin
jambojeef
posted on 5/7/05 at 10:47 AM Reply With Quote
Hello,
In my experience of rebuilding sliding calipers the main seals are very tight around the piston - as youd want them to be!
I just found that using a bit of brake fluid on the piston and making sure that the groove int he caliper body is very clean with no corrosion were good starting points. Then for me, it was just a case of an hour in front of the telly trying to get it to fit - it'll go eventually if its the right size.
Geoff
Mix
posted on 5/7/05 at 10:57 AM Reply With Quote
Try soaking the seal in brake fluid for a while.
Mick
posted on 5/7/05 at 11:00 AM Reply With Quote
thanks for replies. have tried the brake fluid option but not much joy there. will measure the seal and check the size, but does seem overly tight on the piston. if i dont have the right ones, any good leads on places to buy rebuild kits?
cheers all
ned
posted on 5/7/05 at 11:09 AM Reply With Quote
mine went on quite easily as dscribed above. if it's of any help i have some pics on my website.
Ned.
beware, I've got yellow skin
