Author: Subject: This stuff sounds like snake oil
givemethebighammer
posted on 6/7/05 at 10:45 PM Reply With Quote
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=10408&item=4558913008&rd=1
or am I missing something ?
DavidM
posted on 6/7/05 at 10:50 PM Reply With Quote
Is that the modern equivalent of putting sawdust in your sump?
Proportion is Everything
mangogrooveworkshop
posted on 6/7/05 at 11:16 PM Reply With Quote
Or BANANAS in the diff
DEAN C.
posted on 6/7/05 at 11:43 PM Reply With Quote
The only time chemicals work is if you have gummed up oil rings,most engines smoke because they are knackered!
I'm quite sure you knew that anyway.
Once I've finished a project why do I start another?
Snuggs
posted on 7/7/05 at 09:10 AM Reply With Quote
I saw this this on one of the shopping channels a few years back.
The demos were very impressive but the wanted £40 per can.
http://www.agsint.com/system48.shl
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
jestre
posted on 7/7/05 at 01:15 PM Reply With Quote
this stuff has been in the U.S. for years. works great if your only problem is sticky lifters
aweekes1
posted on 7/7/05 at 07:45 PM Reply With Quote
They had a few lines about this stuff in practical performance car last month (?). They said they didn't know if it worked but was worth a go?
So no wiser then, I'll get me coat
wilkingj
posted on 8/7/05 at 07:45 PM Reply With Quote
NOTHING can repair a WORN engine, bearings, pistons, bores, cams, etc etc.
Except NEW parts.
These products usually make the rubbers in the seals swell up thus closing the gaps a little, stopping the smoke / oil etc.
If its Worn out... Its WORN OUT Period.
IHMO Snake Oil
Best Regards
Geoff
http://www.v8viento.co.uk
