Author: Subject: SVA FAIL AT SHREWSBURY
richardhuggins
posted on 21/8/05 at 03:13 PM Reply With Quote
After wating 4 weeks for the test it failed
when I arrived late by 10 mins (I was at the wrong centre, the other one was down the road about 300 yards) Mark the SVA Man was not impressed, my car was cold after spending the night on the trailer outside my house, it was a little smokey to say the least (it has never done that before. But sailed through the emisions test then it whent on the ramp
I said that it had a MOT prior to the SVA "wrong" the first 3 things it failed on were obvious MOT failures 1. brke hoses fouling yhe wheels on full lock 2. headlight alignment out by miles 3. steering u/j nuckle worn. after that it whent well only failing on 3 items not radiused 1 being the ITG air filter the red band round the middle, when the foam was depressed the ring had no radius
te stone guard was sitting proud by 5.5mm Limit 5mm and the headlamp mountin bar no radius at all easy fixes
2 bolts with nylocks not showing enough thread front o/s and rear n/s wheels out of line of body form and finaly the speedo out by light years. cananyone advise me on the brake hoses and speedo my sensor is mounted on the half shaft with 4 magnets ETB say the gap should be 2-3mm but have tried everything ,
any info would be greatful
P.S no one has passed at this test centre first time?
pajsh
posted on 21/8/05 at 04:12 PM Reply With Quote
I have just received my SVA date at Shrewsbury of Thurs 01 Sept so am interested in your comments.
Interesting you note no one passes first time. Things that you have mentioned are the things I think I might fail on.
pajsh
viatron
posted on 21/8/05 at 05:01 PM Reply With Quote
Now i am worried!! I am up for SVA at Shrewsbury on Wednesday morning!! Anyone fancy coming to Craven Arms Wednesday night so i can benefit from your bad luck:
pajsh
posted on 21/8/05 at 05:28 PM Reply With Quote
Being in Crewe I'm a fair way North but would be interested to hear how you get on.
I might post some pics on the forum if I feel brave (and can work out how to do it) as you can get some good advice that way.
I'm probably going to put my test back anyway as I'm waiting on Swansea for a V5 and FoMoCo for an engine statement.
I still don't expect to pass first time though.
pajsh
posted on 21/8/05 at 06:17 PM Reply With Quote
If you are very thorough - you can pass first time... The list you have given is all easy stuff - so good luck on your re-test!
jos
posted on 22/8/05 at 07:44 AM Reply With Quote
I always seem to get an answerphone message whenever I try to contact Shrewsbury SVA centre. Do they only work certain days????
Where is the test centre?? For some reason I thought it was close to Whitehall, is this correct??
coovey
posted on 22/8/05 at 10:48 PM Reply With Quote
Wouldn't guarentee it Helfire, when i spoke to the tester at shrewsbury first thing he said was people don't pass first time with kit cars. really starting to regret choosing shrews for my test next week. Seemed a nice guy just got the impression its a fore gone conclusion. You never know i might break the mould fingers crossed.
posted on 22/8/05 at 11:59 PM Reply With Quote
They do at Derby and Nottingham stations. I'm glad I'm up here and not down there.
pajsh
posted on 23/8/05 at 12:01 PM Reply With Quote
Viatron,
Best of luck for tomorrow at Shrewsbury.
Trust you will post how you get on.
Pajsh
posted on 23/8/05 at 05:29 PM Reply With Quote
Cars can pass at Norwich first time as well . Very helpful tester who seemed to want to pass the car , only had to adjust brake bias while he had a cuppa . No reason any car that is prepaired shouldn't pass at any test centre.
Jon Bradbury
posted on 23/8/05 at 08:13 PM Reply With Quote
Who cares...
...if it doesn't pass first time? You still built it, and got it on the road. The SVA - it's just jumping through hoops. Mine failed on minor things that were fair but the tester said it was the best built RH he'd ever seen and one of the best kit cars. He still failed me, but I was back again the following week and I drove away with the coveted MAC.
Remember, if Shrewsbury are thorough and fail you (where you might have passed at Nottingham) just console yourself with the thought that it's better to know your car's safe than not. A thorough check helps this - even if you fail first time.
richardhuggins
posted on 23/8/05 at 10:11 PM Reply With Quote
I agree with John Bradbury "sound words of wisdom" and I dont mind helping out with the SVA's slush fund
Mark the SVA Man was very fair and helpful
