Arjan356
posted on 5/9/05 at 11:32 AM |
Dzus fastners
Hello,
I want to use Dzus fastners for the bonnet, a MK-indy bonnet.
Can anybody tell me what spring (panelthickness) to use?
Are the Dzus with spring also SVA approved?
Best regards,
Arjan
DarrenW
posted on 5/9/05 at 11:36 AM |
You might find data here
http://www.southco.com/default.aspx
ned
posted on 5/9/05 at 11:59 AM |
i bought some 6-7mm and they're not deep enough. this was for mounting the nose cone.
Ned.
beware, I've got yellow skin
Simon F27
posted on 8/9/05 at 07:08 AM |
While there is a thread on Dzus fastners I thought I would ask a question. I know they with in 2 parts 1 being the spring. Do you make up the brackets
that recieve the fastner or can you buy them and what is the best way to attach to the chassis.
cheers
Simon
Triton
posted on 8/9/05 at 07:12 AM |
You can buy the brackets but they are a universal thing, you are better off making your own.....make them in ali and rivet them on...or use rivnuts,
with holes in brackets bigger than needed to allow adjustment.
gottabedone
posted on 11/9/05 at 10:36 AM |
Watch the length of your Dzus fasteners as they are made for the thickness of steel or ally, no grp panels which are a lot thicker. If you make your
own brackets then you can either vary the thickness or use washers under the springs to get the fit that you want.
steve
madman280
posted on 11/9/05 at 06:25 PM |
There are an endless variety of Dzus fasteners suitable for holding nearly any panel. They come in a number of diameters, lengths and materials.
Coated mild steel, stainless steel, aluminum, anodized, plastic. They can be counter sunk to sit flush with the panel, be self ejecting with a spring
and retained. They can have a groove for a small snap ring so they stay with the panel. As well Southco, Camlock and Airlock all make a range of
quarter turn fasteneres used on aircraft and other things. Check out Wicks site at
http://www.wicksaircraft.com/catalog/product_cat.php/subid=329/ and
http://www.wicksaircraft.com/catalog/product_cat.php/subid=5923/index.
html That should give you an idea whats avalible.
[Edited on 11/9/05 by madman280]
