Author: Subject: 1.8cvh sump on Zetec?
Surrey Dave
posted on 10/10/05 at 10:13 PM Reply With Quote
I'm seeing lots of stuff saying the 1.8CVH sump and pickup pipe fit onto a silver top Zetec, since I maybe changing from 1.8CVh to Zetec this sounds too good to be true , has anyone seen it done?
dave1888
posted on 10/10/05 at 10:22 PM Reply With Quote
IIRC you do need to modify the sump im sure you need to drill extra holes in the sump for bolts
donut
posted on 10/10/05 at 10:59 PM Reply With Quote
NO Dave, don't put a zetec in... are you mad!!
stevebubs
posted on 11/10/05 at 01:56 AM Reply With Quote
With a bit of fettling, yes - it will fit. (The zetec is a development of the CVH block.)
The fettling you'll need to do is with a grinder at the end where the oil pump is - the 2 are slightly different here.
Stephen
Surrey Dave
posted on 11/10/05 at 08:37 AM Reply With Quote
Cant beat a bit of fettling with a grinder!!, I enjoy a professional bodge......
Andy(aka donut): How bad is my old CVH......
Bluemoon
posted on 11/10/05 at 08:46 AM Reply With Quote
Hi Dave,
Why the change? I thought that you'ed only just got the bike carbs up and running??
Dan
Surrey Dave
posted on 11/10/05 at 12:01 PM Reply With Quote
' cos it was there really , the CVH has and continues to serve me well, goes quite nicely now, so I'm not in a panic to do it................but it was part of a long term plan that if the Megajolt and bike carbs worked out they could be moved over to a Zetec quite easily ................also the starter motor and maybe the sump can be used....................... that's an up yours for the ol' 1.8 CVH bashers!!!!!
Bluemoon
posted on 11/10/05 at 01:07 PM Reply With Quote
Sounds like a sound plan, little like mine, CVH first see how it goes, how are you getting on with the new carbs?
saigonij
posted on 11/10/05 at 03:56 PM Reply With Quote
i dont understand.
if your fitting a zetec, why would you want to swap the sumps over anyway?
Is there anything that passes under the engine, or is it that its too low???
Deckman001
posted on 11/10/05 at 04:23 PM Reply With Quote
The Zetec is usually fitted across the car, front wheel drive, between the front wheels, in a locost it will be fitted like the cvh/x/flow/pinto engined cars, rear wheel drive. The engine is also a lot lower than in a std car, this and the baffle requirements make it necessary to modify the original Alloy sump at considerable cost
Jason
piddy
posted on 11/10/05 at 04:34 PM Reply With Quote
saigonij.
Are we to asume from your statement that you have left the standard sump on you Zetec?
Is it from a 1.8 or 2.0? Escort or Mondeo?
Cheers.
donut
posted on 11/10/05 at 04:59 PM Reply With Quote
Nowt wrong with it...at the moment!! I know where you live!
bob
posted on 11/10/05 at 07:34 PM Reply With Quote
An escort zetec series 1 (silver top) sump is a slightly more shallow,maybe around one and a quarter inch so i'm informed.
I've had a look at one fitted in a luego last year at stoneleigh and sure enough it is better than the mondeo bucket.But alas at the end of the day it does depend on height of engine when inline with the gearbox,actually as a matter of point how much angle can or should you put on the prop if you want to raise the engine ?
Anyway dave,yes it is true a cvh sump will fit a zetec block but as said it involves some fetling
bob
posted on 11/10/05 at 08:37 PM Reply With Quote
Also dave
since someone we know has yet again changed there mind i have a 2 litre mondeo sump with its arse chooped off going spare. Rescued attachment building 005.jpg
bob
posted on 11/10/05 at 08:38 PM Reply With Quote
saigonij
posted on 12/10/05 at 07:35 AM Reply With Quote
Im using the original Escort 1.8 zetec sump.
( i think that answers both questions!!! )
So as well as the height, its also a bafflle thingy too. ok, i understand better now...
