Author: Subject: Multi tasking fog lights?
RazMan
posted on 24/10/05 at 09:09 PM Reply With Quote
A slightly weird question but bear with me...
I want to use a foglight which doubles up as a normal tail light when its not foggy. Basically I will use a relay to switch the fog light into 'fog' or 'normal' modes and if you think about it, this is a safety mod as it uses a 'dead' light which is otherwise only used once in a blue moon.
Will Mr SVA have a problem with this? I know that MOT will be ok coz I had this system on my Nissan tin top. In fact I went one stage further with that one - I had two colour fog light / reversing light which switched automatically depending on the mode selected.
[Edited on 24-10-05 by RazMan]
Raz
posted on 24/10/05 at 09:31 PM Reply With Quote
IIRC Fog lights are marked up as such. Standard tail lights are also marked up. Depends on your lenses I guess...
Fog lights are normally polished reflectors for obvious reasons.
omega 24 v6
posted on 24/10/05 at 10:19 PM Reply With Quote
Yep you need a silver reflector and thats no use for the sidelight function. Also you need to be 100 mm away from the brake light.
Petemate
posted on 26/10/05 at 02:44 PM Reply With Quote
IIRC, on our two Cavalier we had, the top lights were brake lights, and the botom ones were tail/rear fogs.
Pete
