ady8077
| posted on 31/10/05 at 01:49 PM |
new handbrake mech
Has anyone seen this?
http://www.marlinracing.co.uk/news_marlin.htm
Looks quite interesting, though probably no good for handbrake turns
  Rescued attachment marlin hand brake
uklee70
| posted on 31/10/05 at 02:37 PM |
Have you looked at the cost!!
for basically two plates behind the brake pads
Plus the calliper cost
I looked at this and decided on these
http://www.rallydesign.co.uk/catalog/product_info.php?products_id=10563
They are a nice bit of kit and at a good price
Lee
JAG
I have seen this and had a couple of thoughts;
1) Efficiency. Will it really hold on 18% (about 1:5) incline as required by Law??? If it will what effort on the handbrake lever??? Below the 400N
legal requirement??? I doubt it.
2) Wear. There is no automatic compensation for pad wear. That means adjusting the handbrake cable every weekend to keep the cable travel down and the
handbrake working.
3) Corrosion. The holes for the cables to pass through the pads will quickly close up (due to rust products) and trap the cable - buggering up
handbrake efficiency and affecting the hydraulic brake system effectiveness.
I wouldn't bother.
Single sided calipers with the integrated handbrake mechanism are more robust, not a lot heavier (3-4kgs Vs 1-2kgs each) and engineered to
VAG/Ford/GM/Honda/Toyota standards. They will repeatedly hold a much heavier vehicle on a 30% incline with less than 400N lever effort.
NO COMPETITION FOR ME
These are the exact type I meant - designed for VW.
[Edited on 31/10/05 by JAG]
Justin
| posted on 31/10/05 at 04:21 PM |
Already been disccussed on the forum a very old trick NBG from both legal and practial points of view.
lsdweb
| posted on 31/10/05 at 04:41 PM |
The Rally Design (VW) caliper won't fit under 13" wheels though _ i was going to buy a pair until I asked them.
mangogrooveworkshop
| posted on 31/10/05 at 05:54 PM |
Handbrake mechanism information and prices:-
Disc Grabber Pad Mechanism Kit (Pat.Pend)
Cable operated SVA & MOT compliant handbrake assembly to fit many standard floating piston calipers currently being sold (contact us with your
requirements).
 Retro fit existing multi piston calipers (i.e. Hi Spec, Willwood, Brembo etc)
 External to the hydraulics
 Cable operated
 SVA & MOT compliant
 Self adjusting for pad wear
 A lighter weight option
 No extra axle on hub fixings required
 Simple pad changes
Note: All handbrake assembly parts available (levers, cables etc) separately.
1) Disc Grabber Pad Mechanism Kit (Axle set)
Retail Price £99
To include:-
4 x Brake pad mechanism (10mm thickness each)
To suit pad size: a) 3.96 (100.6) x 2.21 (56.0) Willwood Dynalite 4pot 7816
b) 2.0 (50) x 13/4 (45) Willwood Dynalite 2pot 7012
c) 3 (76) x 21/2 (65) Hi Spec Ultralite 4pot DP 197/2
4 x Retaining guides
4 x R clips
4 x Pad shear pins
2 x Twist drills
1 x Fitting tips
2) Spacer Kits to suit Hi Spec Ultralite 4pot & Willwood Dynalite to include:
Retail Price £30.00
4 x 12mm CNC aluminium spacer blocks
2 x O ring seals
8 x Cap head screws (as required)
3) SVA compliant production handbrake lever assembly to include:
Retail Price £105.00
2 x Universal handbrake cables
1 x Handbrake Lever inc all operating and trim parts
1 x Cable balance bar parts
1 x Cable clamp rail
1 x Lever cable / floor mount bracket
4) Universal handbrake cables
Retail Price £20.00
ouch
marc n
| posted on 31/10/05 at 06:04 PM |
would carefully removing the alloy fins give the required clearance ????
MkIndy7
| posted on 31/10/05 at 06:12 PM |
Has anybody else seen the Handbrake setup on the new Renault Kangoo vans?
Was looking the other day as I fished the spare wheel out and they look to have a cable operated cylinder for the handbrake.
Should imagine its a similar thing to the Hydraulic handbrakes only its linked by a cable and not directly to the cylinder.
It was behind but inline from the handbrake and then it either had duplicate lines to the drum brake cylinders, or locked the same line, not sure.
Could be of use to some1 maybe?
JAG
| posted on 31/10/05 at 07:45 PM |
It probably would BUT you would then have weakened the Aluminium caliper body. The ribs are added to increase the stiffness of the housing. This means
the fatigue life is extended and the chance of the housing cracking is minimised.
I wouldn't do it and wouldn't recommend anyone else did.
Justin
mnr laptop
| posted on 31/10/05 at 08:05 PM |
agreed if you have to take lots off, does anyone know how close they are to clearing ????? it may only be a fraction
Matthew_1
| posted on 31/10/05 at 09:51 PM |
I looks like it's not the caliper but the handbrake mechanism that the problem - could that be adapted to fit under 13" wheels?
The same is true of the sierra calipers, they don't quite fit under a 13" wheel, but I adapted the handbrake lever on the caliper a bit
and now they fit fine.
lsdweb
| posted on 31/10/05 at 09:58 PM |
Rally Design promise a fitting kit (brackets etc) but say it won't go under 13" wheels - I wouldn't chance any filing - Peugeot /
Citroen calipers do - see here
and here.
Regards
Wyn
| posted on 31/10/05 at 10:02 PM |
what would be wrong with having a handbrake that worked like sticking a bar through a bikes spokes? You could bolt a small inboard disc in by the
diff, and just have a lever to completely sieze it up. It would have no problem holding the car as its not relying on friction like normal brakes.
MikeR
| posted on 31/10/05 at 11:27 PM |
testing it would be "interesting" at MOT time.
NS Dev
| posted on 1/11/05 at 12:01 AM |
it would be a bit like a mate's old MK2 escort rally car. The "handbrake" was a strategically drilled hole in the transmission
tunnel, and an old screwdriver on a piece of string!!
I kid you not, the screwdriver, when dropped through the hole, went through the yoke of the prop, therefore stopping the car rolling away!!
Very iffy but it got by the MOT man and RAC scrutes for 3 years!!
[Edited on 1/11/05 by NS Dev]
Rorty
| posted on 1/11/05 at 12:11 AM |
What about a similar contraption using a push/pull cable attached, in line, to a stout pin that enters a hole in the disc.
Cheers, Rorty.
uklee70
| posted on 9/11/05 at 12:09 PM |
I have the Rally Design vw calipers for my car
I'm running 13 x 7 cxr rims
They will fit !!!!!!!
or they will by the time Martin has finished with them
I will post the mods needed once we are at that stage
Lee
