Author: Subject: Electric choke
vintagebuilder
posted on 27/11/05 at 02:17 PM Reply With Quote
Electric choke
Afternoon All,
I've now wired up the electric choke on Weber 32/36 via ignition switch. After a few minutes the flaps fully open. However when the ignition is switched off the flaps will not close on their own no matter how long I wait.
Any help much appreciated.
Regards
Avoneer
posted on 27/11/05 at 02:42 PM Reply With Quote
Hi David,
Tom knows something about this I think.
Will we see you next summer in your car?
I'll be there in my 2nd!
Pat...
theconrodkid
posted on 27/11/05 at 02:57 PM Reply With Quote
tried pumping the throttle to re-set the flap?otherwise try turning the element to adjust it
who cares who wins
pass the pork pies
MkIndy7
posted on 27/11/05 at 04:03 PM Reply With Quote
Isin't the Auto choke fed from the Alternator?
I'm sure it is on ours, either from the screw connector that pushes on to the alternator or part of the bigger plug.
"flaps will not close on their own no matter how long I wait", I thought there was only 1 controled by the choke.
It does take quite a while to return, possibly till the water in the engine/manifold has also cooled.
vintagebuilder
posted on 27/11/05 at 04:25 PM Reply With Quote
Ian,
I'm using a Suzuki alternator so the plug is different to a Pinto one. Tom suggested using a switched live connector to the choke, thats what he has done.
Pat,
Nearly there now. The finishing touches seem to take longer than the main build.
Nearly th
theconrodkid
posted on 27/11/05 at 05:18 PM Reply With Quote
if it was an alternator fed unit its not 12v but 3 or there abouts,better check
who cares who wins
pass the pork pies
Dusty
posted on 27/11/05 at 11:47 PM Reply With Quote
I ran my DFTH electric choke off a six volt tapping off the alternator. Could also measure the resistance of the choke element and put an equal resistance in series with it. Make sure it runs off an ignition live. Could be that the element in your choke is now fried!
