joolsmi16
posted on 30/11/05 at 11:53 PM |
throttle cable size
Hi, being looking for cable to use for the throttle any idea of size? the listing is Wire No./Strands and Dia.
Aboardman
posted on 1/12/05 at 12:05 AM |
when my cable broke on my car, used bike brake cable no problems with it.
Sven
posted on 1/12/05 at 06:39 AM |
I like these mountain bike brake cables:
http://www.pricepoint.com/detail/11115-050_AVDFJ8-3-Parts-49-Cables/Avid-Flak-Jacket-Cable-Set.htm
Easy to figger out how to attach them to just about any throttle linkage and they're not too stiff if you have to turn them around something ...
donut
posted on 1/12/05 at 07:53 AM |
So if i used a bike cable i presume a rear brake cable is required?
Aboardman
posted on 1/12/05 at 08:02 AM |
does not matter, depends on the length of cable you require, if you get some solder nipples (some older bike shops have them) you may get 2 cables out
of a rear cable.
Kissy
posted on 1/12/05 at 09:03 AM |
or solderless nipples - available from any good car shop. You can also use the brass bit out of choc-block electrical connectors.
If you need a really long wire go for a tandem rear gear wire, or brake. Note, gear wires are generally a bit thinner and more flexible.
Humbug
posted on 1/12/05 at 12:37 PM |
I used a bike brake cable with a double lecky connector (choc block type), i.e. cable through both parts, both screwed tight and a dab of superglue
for good measure!
so far, so good!
posted on 1/12/05 at 12:57 PM |
Derailleur cable is good for replacements and is more flexible than brake usually.
chrisf
posted on 1/12/05 at 02:26 PM |
I used Avid Full Metal
Jacket bicycle brake cables. It came as a kit and I had more than enough left over. Two people can easily share one kit.
It has a stainless braid over the the inner wire and is quite flexible. I think these are the best bike cables money can buy.
--HTH, Chris
Mark Allanson
posted on 1/12/05 at 05:04 PM |
I am probably missing something here, but why not use the cable from the donor, of a new replacement, a sierra one is only £8.50 patern
Aboardman
posted on 1/12/05 at 06:17 PM |
"I am probably missing something here, but why not use the cable from the donor, of a new replacement, a sierra one is only £8.50 patern
because this a locost site and bike cables only cost about £3
Mark Allanson
posted on 1/12/05 at 10:57 PM |
All this fuss fro a fiver
tadltd
posted on 2/12/05 at 05:49 PM |
Hardware shop - if you're insistent on saving pennies. Next to the chain link for fencing...
25-50p a metre.
Best Regards,
Steve.
www.turnerautosport.com
