Author: Subject: Yoko A539 Problem
liam.mccaffrey
posted on 17/12/05 at 01:55 PM Reply With Quote
Yoko A539 Problem
Just had a set of Yoko A539's put on my alloys. Problem is I thought you were supposed to line up the red dot with the tyre valve this hasn't been done on any of the tyres. is this a mjor problem and should i get the to change them
Cheers Guys
Build Blog
Build Photo Album
zilspeed
posted on 17/12/05 at 02:12 PM Reply With Quote
You're quite correct - but you do have to tell the fitter that's what you want done.
madman280
posted on 17/12/05 at 02:56 PM Reply With Quote
If he balanced them and there isn't much weight clipped or stuck on it doesn't matter. The dot is there just for balancing purposes. It makes the heavy or light spot in the tire. Which it is depends on the tire manufacturer.
iank
posted on 17/12/05 at 03:08 PM Reply With Quote
No red dot is not the heavy point that is a yellow dot and goes by the valve. If you have a red dot as well by it goes by a notch/dimple on the rim marking the wheel low point.
http://www.carbibles.com/tyre_bible.html
See "What if both dots are present?" and the para above.
Your fitter might well have put them on correctly - if your lucky
liam.mccaffrey
posted on 17/12/05 at 04:19 PM Reply With Quote
i have had a look i can't see any notch, would it be obscured by the tyre?
Build Blog
Build Photo Album
