<<  1    2    3  >>
Author: Subject: Spraying - advice please
Avoneer
posted on 26/12/05 at 12:50 AM Reply With Quote
My plan is to spray my scuttle, bonnet, nose cone, rear arches and cycle wings in either plain black or gray and then laquer everything with some silver metal flake in the laquer.
I am no sprayer, but can borrow a compressor.
How hard would it be for me to spray everything in the base colour and then take the parts to a bodyshop to be laquered, or is the laquer bit easy enough?
Anyone know roughly how much paint I will need for the base coat and the lacquer?
Pat...
froggy
posted on 26/12/05 at 09:15 AM Reply With Quote
a litre of each will be plenty, the tricky bit is getting the base coat on even .
if your using metal flake youll need an anti static strip and a fog light fitted underneath your car, oh and furry dice
Avoneer
posted on 26/12/05 at 10:29 AM Reply With Quote
So after sanding everything down:
1 - 3 coats of primer rubbing down between each coat with 400 grade wet n dry.
1 - 3 coats of cellulose base coat mixed with cellulose thinners (50-50 for 1st coat, 40-60 for 2nd coat and 30-70 for final coat - 2nd number being the paint).
1 - 3 coats of cellulose laquer mixed with cellulose thinners as above.
How does that sound?
Pat...
froggy
posted on 26/12/05 at 10:50 AM Reply With Quote
i wuoldnt bother with cellulose ,go for 2pack surfacer (primer)and single pack base coat and laquer. if you really want the glitter then put it in your first laquer coat and not in any other to give depth to the shine. the base coat if tis a metallic finish give it a good first coat then flat with 1000grade hit it again then leave it for laquer.its ambitious for a first go but its all in the prep.
if you have the room hang everything up to paint it as anything flat will get covered in poo if your doing it at home.
if the compressor is under 3hp/14cfm keep aneye on the pressure set your gun for 40psi and if the compressor kicks in stop spraying til tis full again.
i shouldnt worry too much about thinner ratios as youll have to flat and polish the laquer anyway
omega 24 v6
posted on 26/12/05 at 10:59 AM Reply With Quote
Should that not be 2nd number for the thinners Avoneer?
rayward
posted on 26/12/05 at 11:08 AM Reply With Quote
Pat, if you were thinking of doing it in your garage, then forget it, integral garage is not good for spraying(i know from experience!!),i thought it should be more thinners:less paint on your final coats aswell
Ray
froggy
posted on 26/12/05 at 11:12 AM Reply With Quote
if it wasnt being painted in a garage then yes perhaps thin the final laquer coat but as there WILL be lots of bits to flat out of the laquer then its not worth it
Avoneer
posted on 26/12/05 at 11:16 AM Reply With Quote
Yes - got that bit with the thinners/paint the wrong way round.
Froggy - isn't that 2 pack and single pack the nasty stuff and cost more?
Ray - thinking of hiring a bloddy big extractor fan and covering the walls and floor in big plastic sheets. Was it the smell that was the problem?
Pat...
Mark Allanson
posted on 26/12/05 at 11:29 AM Reply With Quote
Pat,
You will need 1+1 litre etching high build primer, 1 1/2 litres of polyester basecoat and 1 litre thinner, 1 1/2 litres of single pack clear.
2pack will kill you, a large extractor fan will just suck dust onto your work, and metalflake in the lacquer is a beast of a job, even holoflakes are difficult.
If you base up the car and take it to a bodyshop for clearing, you will have to do it in 20 mins as this is the critical recoat time, clear it in more than this time, it will all peel off in about 3 months like sunburn.
If you go the holoflake route, put down a black basecoat, and spray with flake colour of your choice, remember my wheels!
froggy
posted on 26/12/05 at 11:33 AM Reply With Quote
2 pack surfacer is officially nasty but its overblown because of a minute amount of iso cyanatre in it . it wont give you any probs with fibreglass and gives a good thick primer coat so you should only need two coats before base coat .
you will need a mask anyway as celly thinners hasnt exactly got vitamins in it has it!
2k primer is about £13 a litre with activator and base coat is around £10 per half litre mixed, base coat thinners £6 laquer around £12 litre
the best finish you can hope for is orange peel in the laquer which means you have plenty on to flat off with 1200 wet and dry.
cellulose is a pain to work with as its very thin and takes plenty of coats to get a good shine .modern base coat shells off much quicker so less chance of bits in the paint. as far as mixing i use the drip method which is a welding rod dipped in the pot and pulled out should go drip drip drip as you say it will be fine.
plastic sheets wet the floor and dont have the gun pressure and youl be ok but you will have to flat and polish everything as you would with celly.
reckon about £80 for paint and bits like tack rags ,stopper,tape.
take your time with the primer and get plenty of laquer on and it,ll be fine after flatting farecla g3 then g6 and wax ,job done
Mark Allanson
posted on 26/12/05 at 11:40 AM Reply With Quote
Stunned silence
froggy
posted on 26/12/05 at 11:43 AM Reply With Quote
is that directed at me?
posted on 26/12/05 at 12:35 PM Reply With Quote
I have two friends that worked with 2 pack that didn't take proper precautions . Both are off work for that reason! DON'T TAKE CHANCES.
froggy
posted on 26/12/05 at 01:17 PM Reply With Quote
i wasnt advocating drinking the stuff! im sure that non iso filler primers are available but for a one off with a decent mask i cant see a problem.
Mark Allanson
posted on 26/12/05 at 04:30 PM Reply With Quote
Thats why you cannot get life insurance, my sympathy to your family
posted on 26/12/05 at 04:36 PM Reply With Quote
It's not the iso-cyanate that's the real problem - it's the fact that any spray particles that arrive in your lungs will never be absorbed or removed (unlike cellulose).
This exposes the lungs to a high risk of either cancer or a similar disease to silicosis (the miner's disease).
Best left to the professionals...
froggy
posted on 26/12/05 at 05:41 PM Reply With Quote
i think i did say use a good mask though!
surely the same goes for polyester based paints then and fettling fibreglass too?
Mark Allanson
posted on 26/12/05 at 05:59 PM Reply With Quote
I agree with most of Davids post, but the isocyanate IS a real problem, it is cumulative. Your body has a certain threshold of tollerance to it. It may be 250mg per 1000g or it may be 1mg per 1000g, and there is only one way to find out.
Especially at this time of year I am a bit sensitive (sorry froggy), I have taken presents to a 6 year old and an 8 year old who don't have a Daddy, he died when they were 3 and 5 years old at the age of 32. We tried to make the last 9 months of his life the best, but nothing would compensate for having him back, it may not have been isocyanate, but a sprayer for the last 8 years of his life, and lung cancer in a non smoker is very unusual.
DON'T use isocyanate at home, you should't be able get hold of it, unless you are a registered bodyshop, but if the local supplier does supplier does sell it to you, I personally would report them to the local EPA officer in the council.
The average length of a book build is 2 1/2 years, you could die in less.
Live to enjoy you car, don't use 2K at home
Merry Christmas
Mark
stevebubs
posted on 26/12/05 at 06:13 PM Reply With Quote
Why is it that bikes etc with expensive airbrush art don't peal? These can take weeks between base coat, graphics being applied and final lacquer.....
Is there something special they do, or am I just not grasping something fundamentally different?
stevebubs
posted on 26/12/05 at 06:14 PM Reply With Quote
Can't speak on the former, but definitely the case with fibreglass....
Avoneer
posted on 26/12/05 at 06:26 PM Reply With Quote
What makes the metal flake so hard to spray???
Can I put it in the clear coat instead of the laquer?
If I give up with the metal flake idea, will I still need any clear coat or lacquer???
Pat...
Mark Allanson
They lacquer that days work, then scotch it back and start again, I don't think the fancy art work tends to get the same day to day wear that the avaerage car gets
Triton
posted on 26/12/05 at 06:34 PM Reply With Quote
Spraying is a black art and best left to those who know what they are doing and have the right kit to do it with.
www.tritonraceseats.com
www.hairyhedgehog.com
froggy
posted on 26/12/05 at 06:38 PM Reply With Quote
fair comments 2k isnt for home use but i think the original thread was about painting at home in general. the point i was trying to make was that a lot of us dont have the budget for professional paint finishing so home painting is something that must be considered and you can get reasonable results with basic kit.
posted on 26/12/05 at 07:13 PM Reply With Quote
I should also add that I lost a neighbour to lung disease a few years back - he specialised in spraying dinky toys in company livery for promotional events. He was very bad with health and safety, using all sorts of paint in his airbrush, without a mask. These paints included 2-pack iso-cyanide etch primer. which he used a lot.
He left a wife and 2 teenage daughters.
DJ
<<  1    2    3  >>
