kevin booth
posted on 3/1/06 at 07:24 PM |
chassis on its way
what does this look like
mookaloid
posted on 3/1/06 at 07:41 PM |
Very nice
But what is this weld for?
andyps
posted on 3/1/06 at 08:00 PM |
quote: Originally posted by mookaloid
Very nice
To join two bits of tube together??
907
posted on 3/1/06 at 08:17 PM |
Absolutely Superb
Paul G
[Edited on 3/1/06 by 907]
kevin booth
posted on 3/1/06 at 08:20 PM |
st/st chassis
had to widen bottom rail to get room for starter motor, put weld under engine mount for extra strength.
posted on 3/1/06 at 08:30 PM |
Thats quick work
gazza285
posted on 3/1/06 at 08:31 PM |
quote: Originally posted by rusty nuts
Thats quick work
Pretty slick work, less than an hour! It takes most of us months to get that far.
posted on 3/1/06 at 10:12 PM |
you probably know you're missing on of the braces in the engine bay, are you planning on adding any? Apparently this is one of the twistiest
area of the whole chassis.
kevin booth
posted on 3/1/06 at 10:39 PM |
chassis brace
Still got to finish braces and rear top of chassis, but just had to get it going, so i put it together. Planning on finishing chassis in next two
weeks.
Avoneer
posted on 7/2/06 at 08:59 PM |
I think you will need a bit of bracing from the top bar that holds the steering column down to the chassis as it will flex as it is.
Pat...
Marcus
posted on 7/2/06 at 09:18 PM |
Pat, that's similar to the way I did mine, the column acts as the third point in the system, so very little flex.
Marcus
Marcus
Because kits are for girls!!
Avoneer
posted on 7/2/06 at 11:11 PM |
Mine to, but if I wiggle the wheel up/down, the top bar flexes a bit so I put two braces in place.
Might be better made than mine though
Pat...
