Author: Subject: Which Battery for My Indy Blade?
mike smith1
posted on 4/1/06 at 02:32 PM Reply With Quote
Hi Guys
Just wondered what the most common battery was to use with the blade engine,
and how much you paid?
Cheers Mike
shortie
posted on 4/1/06 at 02:47 PM Reply With Quote
I use a standard blade one and have had no problems but alot of people use a car one I believe.
Rich.
zxrlocost
posted on 4/1/06 at 03:02 PM Reply With Quote
the original bike one mike but you can get ones with slghtly higher amps etc
Genesis
posted on 4/1/06 at 03:04 PM Reply With Quote
I have bike battery as it has a battery box/relay unit as standard.
If you have an MK battery tray a 069 is a perfect fit - it has pillar terminals.
Going fishin'
mike smith1
posted on 4/1/06 at 03:12 PM Reply With Quote
i was on the understanding i needed a car battery for light etc,
a 069 is that a car or bike battery Genesis?
Cheers Mike
zxrlocost
posted on 4/1/06 at 03:38 PM Reply With Quote
mike honestly mate a bike battery is plenty up to the job and about a quarter of the size
mike smith1
posted on 4/1/06 at 03:43 PM Reply With Quote
Looks like a bike battery it is then!
Cheers Chris
Mike
Genesis
posted on 4/1/06 at 03:49 PM Reply With Quote
069 is a Car Battery. Bike battery is upto it - if a litle more interactive - with trickle charging etc. Bear in mind that most bike batteries don't usually run two headlights and two main beams otherwise it's fine.
Going fishin'
Andy W
posted on 4/1/06 at 04:39 PM Reply With Quote
I can't think of many super bikes that DON'T run two headlamps.
Genesis
posted on 4/1/06 at 04:48 PM Reply With Quote
There isn't many now but in 1997 I bet there was a few. Also some superbikes don't have two headlights one is main and the other is full beam - so not on together. Let's not forget there is also a reverse light (where fitted) and a fog light, two extra indicators - not to mention hazards - there 'could' be more load on a bike battery than it was initially designed for - but it'll probably cope with it. Well... mine has upto now!
I saw a bike on the hard shoulder t'other day with Hazards on WTF!?!?
[Edited on 4/1/06 by Genesis]
Going fishin'
Genesis
posted on 4/1/06 at 08:43 PM Reply With Quote
Charlie - get yer trimmings down....
Going fishin'
mike smith1
posted on 5/1/06 at 02:32 PM Reply With Quote
Just been on to the local bike place they want £40 for a blade battery!
Is the fiesta one suitable as i have a friend who works for ford so i can get one a little more "locost"!
I understand they have been used
Cheers Mike
stevebubs
posted on 5/1/06 at 03:20 PM Reply With Quote
http://www.mdsbattery.co.uk/shop/productprofile.asp?ProductGroupID=976&Brand=Honda&DepartmentName=Motorcycle%20batteries&DepartmentID=155
RichieC
posted on 5/1/06 at 05:08 PM Reply With Quote
MDS are the cheapest Ive found, but £40 isnt bad if its a good brand (Yuasa or Varta).
A bike battery is fine. Its a lot smaller and lighter than even the new crop of car batteries. If you have any doubts get a good quality 12 or 14Ah rating and it will be fine, there isnt much extra running on a BEC and (big) bike batteries dont tend to be maxed out anyway.
Rgds
Richie
RichieC
posted on 5/1/06 at 08:13 PM Reply With Quote
Car batteries are definately cheaper and more powerful. I priced one up at £20 for a 30Ah, they come at the expense of weight though.
Just depends what you are building your car for
Rich
