oliwb
posted on 7/1/06 at 07:14 PM |
Issue with a pump
Sorry to post in the wrong bit but reconed you guys would know better....
Ok so, bought myself a fuel pump of a ZX7r to go with my ZX7r carbs on my pinto. Bought on ebay so first off attach contacts to the battery and see
if it does anything....got a kind of click then that was it.....figured well it's doing something and haven't they got some kind of
automatic cut-off....got it fitted to the car and all wired in but don't get a click now when i turn on the ignition.....circuit is OK eg 12v
and is workinf correctly just no action with the pump.....Haven't tried it with petrol in the tank yet as not at that stage yet.....should I
worry about this now and buy an r1 one at £25 new or leave it and hope for the best when it comes to starting it! Cheers Oli.
posted on 7/1/06 at 07:18 PM |
doesnt the fuel libricate the pump? ie you shouldnt run them dry? I certainly knackered one pump (not bike though) when i ran out of fuel.
oliwb
posted on 7/1/06 at 08:06 PM |
ummmm.....didn't really run it though....literaly the thing just clicked once....I've never used a motorbike one before but the previous
pacet one would click like crazy! until you turn it off....this one just did it once then stopped....is it buggered or is this vaguely normal???
Cheers Oli.
posted on 7/1/06 at 08:20 PM |
im no expert, but they run til pressure builds up, to whatever psi it is designed for. On a carb'd bike thats probably 2psi, IIRC. Try it and
see, theres (probably) nothing to lose!
oliwb
posted on 7/1/06 at 09:45 PM |
Cool, guess I'll leave it for now until I get the mani sorted and ready to start the car, chuck some fuel in and see what
happens.....thanks...Oli.
paulf
posted on 7/1/06 at 09:47 PM |
Try giving it a gentle tap with a hammer, if its anything like an SU pump it may start working.On SUs the points stick and cause them to stop, once
going they are usually ok until left unused for some time.
Paul.
Genesis
posted on 7/1/06 at 10:15 PM |
The fuel is used to lube them - you may get lucky and it's ok. Nothing to loose have you?
Going fishin'
gary gsx
posted on 7/1/06 at 10:28 PM |
Is it the type of pump you can take the bottom off? My zxr one older than zx7r had contacts in the bottom of it and they used to stick worth a look
oliwb
posted on 8/1/06 at 05:47 PM |
There is a black kind of cap on one end where the wires come out of....my mate managed to pull it off the other day and not put it on again! We did
eventually manage to get the end cap back on but there were some very strange nmetal and electronic stuff under it.....(assume the points you guys
mentioned) I'll have another look at it probably and see what happens when I actually need to use it....if no joy I'll buy a new R1 one
for £25.....Cheers Oli.
