Author: Subject: and today's second tip - wheel studs
posted on 15/1/06 at 08:34 AM Reply With Quote
Had to fit 4 wheels studs, 2 per side (had to cut donw longer ones and cut thread but that is antoher story).
To fit to half shaft flange, fit a wheel and do up the nut.
Do not attempt to press in with a vive as it will not be pushed in straight (ask me how I found that out). Luckily was able to get the wheel nuts on and corrected alignment, wasn't out by muuch but enough to make wheel nuts awkward to fit and then do up the wheel nuts. sorted!
donut
posted on 15/1/06 at 08:49 AM Reply With Quote
What's a vive?
wilkingj
posted on 15/1/06 at 09:33 AM Reply With Quote
I pressed mine in with a 4lb sledge hammer (gently)
Best Regards
Geoff
http://www.v8viento.co.uk
ray.h.
posted on 15/1/06 at 12:03 PM Reply With Quote
Short piece of gas pipe a large washer and a wheel nut on backwards got all my studs on in about an hour,dead easy and straight.
givemethebighammer
posted on 15/1/06 at 09:07 PM Reply With Quote
same here but used and old socket instead on the pipe.
locoboy
posted on 16/1/06 at 06:34 AM Reply With Quote
same here but just used the wheel!
Locoboy
