Author: Subject: Floor mounted pedals
Ian D
posted on 31/1/06 at 09:31 PM Reply With Quote
Has anyone advice on fitting floor mounted pedals in an Avon?
Who supply them and what are the issues. Im trying to get away from the Sierra pedals. I already have a new Sierra dual circuit master cylinder, reservoir and sierra compensation valve. So im trying to avoid buying additional master cyliners bias valves etc.
My thoughts are to use the components I already have.
Ian
Lightning
posted on 31/1/06 at 10:15 PM Reply With Quote
I fitted floor ones. Recommebd putting the ali panel on the outside of the foot well, tunel side to get greater width. No other problems. I used ST ones but most appear to be the same such as Leugo etc Rescued attachment Chassis 016.jpg
gary gsx
posted on 31/1/06 at 10:28 PM Reply With Quote
How wide are the st pedal boxs???
Avoneer
posted on 31/1/06 at 11:24 PM Reply With Quote
MK's will weld on and use the original Sierra master cylinder.
Very simple and neat as well.
Pat...
gary gsx
posted on 1/2/06 at 01:18 PM Reply With Quote
Does anyone have pics of MKs pedal box possible price to
Ta Gary
Danozeman
posted on 1/2/06 at 01:58 PM Reply With Quote
The price is on Mk's website. Here I think they are 60 quid or so.
Dan
Avoneer
posted on 1/2/06 at 05:04 PM Reply With Quote
See here:
http://www.locostbuilders.co.uk/viewthread.php?tid=22571
Pat...
soggy
posted on 1/2/06 at 06:07 PM Reply With Quote
mines also fitted with st floor mounted pedals
if at first u dont succeed use a bigger hammer!
Ian D
posted on 2/2/06 at 07:55 PM Reply With Quote
Guys,
Thanks for your views and advice. I think im going to go for the MK solution and weld a 25mm tube to the floor plate and mount the pedals on it. The main reason being that I can reuse my Sierra master cylinder.
Its only when you start that you see some off the challenges or do I meam problems!
Ian
mat.price
posted on 2/2/06 at 08:06 PM Reply With Quote
i have the leugo floor mounted pedals on my avon, the one thing that im having trouble with is how or where to fit the brake light switch.
any ideas would be helpfull as we on the subject of floor mounted pedals
thanks matt
soggy
posted on 2/2/06 at 08:20 PM Reply With Quote
i fitted a hydraulic brakeline switch.
