Author: Subject: How much throttle cable ?
Matthew_1
posted on 4/2/06 at 12:18 PM Reply With Quote
Can anyone measure how much throttle cable comes out as you press the gas pedal through it's full travel please. I'm just building some pedals and want to know how high to site the cable above the pedal so it opens the butterflies completely.
I'm going to be a using a zetec on Jenvey throttle bodies if thats any extra needed info?
Cheers.
posted on 4/2/06 at 12:33 PM Reply With Quote
You actually don't want to open the butterflys 100% --- only 99.5 % --- 100% and you run a high risk of breaking the throttle cable or worse twisting the injector body/carb spindles.
Matthew_1
posted on 4/2/06 at 01:00 PM Reply With Quote
That's really really helpful, because that's what, an extra 0.1mm difference between the measurement I'm looking for, and the one which will open the bodies 99.5%.
I must remember that if anyone actually answers my post with a measurement, to take 0.1mm off ....
I bet you're jolly clever though, I give up with this board, it's full of assholes.
Mix
posted on 4/2/06 at 01:37 PM Reply With Quote
Just Another As***le
For what it's worth,
1. My Jenvey throttle linkage requires 22mm cable movement stop to stop
2. I, for one, have benefitted so much from advice freely given on this forum that I find your generalisation both erroneous and offensive.
Mick
posted on 4/2/06 at 02:01 PM Reply With Quote
Don't worry with that attitude not many will answer your posts.
The point was you have to make the pedal travel ajustable or you will ruin some very expensive bits of gear. At most club motor sport events you will see somebody repairing a throttle cable because they forgot just this point.
PaulBuz
posted on 4/2/06 at 04:12 PM Reply With Quote
I don't profess to be an expert on Jenveys, but I'm willing to bet that the distance you need will be somewhere between .1mm & 1000mm.
Hope this helps, from a friendly asshole
Paul
CairB
posted on 4/2/06 at 04:29 PM Reply With Quote
Why not ask Jenvey it as it depends on the actuator quadrant and linkage used?
I did mine the other way when I designed the throttle actuator quadrant that gave a slow inital opening rate then increased towards full throttle.
I also ensured that the pedal bottoms out on the stop before the buterflies come to a stop to prevent damage.
You can get some good advice on this site from peeps with something to contribute as long as you don't p**** them off
Colin
[Edited on 4/2/06 by CairB]
Confused but excited.
posted on 4/2/06 at 05:58 PM Reply With Quote
take 0.1mm off ....
As far as I can see there is only one!
andyharding
posted on 4/2/06 at 06:40 PM Reply With Quote
Good job fireworks don't have such a short fuse
NS Dev
posted on 4/2/06 at 06:42 PM Reply With Quote
Ask a silly question get a silly answer...................................................................depends on the pedal pivot height, the throttle linkage used, whether you have roller throttles....etc etc etc etc etc etc etc et c
posted on 4/2/06 at 07:56 PM Reply With Quote
How long is a piece of string? I suggest you are get of your arse and find out from Jenvey what options they offer for cable quadrants.
Then you can do some shopping and hopefully get a bargain on a better attitiude.
[Edited on 4/2/06 by MikeRJ]
gazza285
posted on 5/2/06 at 01:34 AM Reply With Quote
I think most throttle actuators have an elastic device so that you can have full opening without breaking the cable, why people don't allow for this when fitting aftermarket stuff I don't know.
gazza285
posted on 5/2/06 at 01:38 AM Reply With Quote
Too true, I'm afraid. Too many people answer without knowing the correct response.
indykid
posted on 5/2/06 at 10:41 AM Reply With Quote
too many people ask questions with so many variables to them, and so little real information, that it often warrants answers without the correct response.
fwiw, i think BT gave a more than adequate response. it was the original question that was poor, as well as the following attitude.
tom
