Author: Subject: Compact servo's
chrisg
posted on 6/2/06 at 06:56 PM Reply With Quote
Compact servo's
Following on from the earlier discussion, can anyone recomend a compact servo & M/C?
I'd like it to have M10 fittings if possible.
Chris
chrisg
posted on 7/2/06 at 06:55 PM Reply With Quote
Er....thanks.
cheers
Chris
JAG
posted on 12/2/06 at 11:53 AM Reply With Quote
Chris, my Locost has servo assisted brakes. The servo came form a Nissan Micra.
It does make things cosy at the end of the drivers footwell and I had some difficulty fitting the clutch m/cyl. It does fit though and it works very well. Light pedal but lot's of 'feel'.
Justin
chrisg
posted on 12/2/06 at 05:58 PM Reply With Quote
Thanks justin, do you happen to know if it has the M10 fittings? and which Model of micra it's from?
Chris
JAG
posted on 12/2/06 at 08:24 PM Reply With Quote
Hi Chris,
yep it's M10 ports all round. Which model is a good question and I don't know the answer. I got it via another route - all I know is it has the 20.64mm diameter, steel tube type m/cyl'.
You can see it in this picture;
The LH engine mounting, made by my own fair hand!
[Edited on 13/2/06 by JAG]
Justin
chrisg
posted on 13/2/06 at 01:12 PM Reply With Quote
Thanks mate, looks like the early square shaped Micra.
Chris
