Author: Subject: Advice / Help with Pug problem please
swood
posted on 9/2/06 at 08:58 PM Reply With Quote
Evening Gentlemen, am still plugging away with my MK Indy off and on & visit site regularly, but keep getting interuptions such as this !!.
Daughter has Peugeot 106 Key Largo very good for age but I have to replace the rear metalastic bushes on the front lower wishbone / suspension arm, have removed old sleeves of failed bushes from arms but wish to know approximately what angle to set the new ones at before pressing them on.
As usual the Haynes is about as much use as a chocolate teapot!, hopefully cartoon is attached, I was thinking of having the ? angle at about 10 degrees any one know otherwise?
When you're up to your ass in alligators you tend to forget the initial objective was to drain the swamp !.
Ketchup
posted on 9/2/06 at 10:58 PM Reply With Quote
these are the bushes that have the fixings inside the car in the footwells unless i am mistaken... in the past i have pressed them on just over horizontal to the wishbone, 10 degrees should be fine in my view, i have never had anyone come back with a problem, and thats not cause they found a ditch
Kissy
posted on 10/2/06 at 06:59 AM Reply With Quote
What does the other side look like?
swood
posted on 10/2/06 at 08:45 AM Reply With Quote
Pug Problem
Thanks Ketchup, correct they bolt up under the footwell, think 10 degrees looks about right, because when the cars on the ground wishbone looks about that angle, just didnt want them new bushes overloaded, or over tensioned.
Kissy - the other sides is f*****d too!
but I did think of that !.
