Author: Subject: where did you get yours
jay taylor
posted on 18/2/06 at 10:27 AM Reply With Quote
building locost gts 2l dohc efi and just wondering where some of you got your fuel tanks if not from gts
kind regards
jay
graememk
posted on 18/2/06 at 10:29 AM Reply With Quote
ebay
DIY Si
posted on 18/2/06 at 10:37 AM Reply With Quote
Planning on making mine. But mainly because I'm too tight to but one
jay taylor
posted on 18/2/06 at 10:41 AM Reply With Quote
i would make my own but welders and me dont go together
flak monkey
The GTS alloy tanks have mounting brakets welded to the bottom IIRC so you dont need to use straps to hold them in. The brackets just bolt to the two short tubes that run parallel to the length under the tank.
Sera
http://www.motosera.com
posted on 18/2/06 at 10:47 AM Reply With Quote
Some welders are really nice people, try to get along . Try Allyfab , Bryn is at most of the shows and will make one to your design and measurements.
jay taylor
posted on 18/2/06 at 10:53 AM Reply With Quote
nice one pete
UncleFista
posted on 18/2/06 at 12:07 PM Reply With Quote
He's not a registered trader, but I got my excellent ally tank from "Deneo" on this site, search for him and ask, was cheap too
Tony Bond / UncleFista
flak monkey
posted on 18/2/06 at 12:41 PM Reply With Quote
The tank fit OK Mark? I have seen some of his tanks and they look rather nice.
PS Your top wishbones are on the wrong way around
[Edited on 18/2/06 by flak monkey]
Sera
Ian Pearson
posted on 18/2/06 at 01:08 PM Reply With Quote
Triumph Spitfire tank fits nicely.
jay taylor
posted on 18/2/06 at 07:54 PM Reply With Quote
thanks for all the help buys. i think i heard car builder sollutions plastic tank is the same in dimensions as darrens is this true?
BKLOCO
posted on 20/2/06 at 01:18 PM Reply With Quote
I tried the plastic tank before finally settling for the GTS aluminum one.
The plastic tank will not fit directly onto the chassis, it fouls the panhard rod. You would need to reposition it higher similarly to the way CaLviNx is suggesting.
GTS sells these plastic tanks as well as the alloy ones.
