jay taylor
posted on 21/2/06 at 06:31 PM |
pedal set
just a quick question about the adjustable pedal set can anyone tell me what parts that contains?![](/images//smilies/bigsmile.gif)
Gav
posted on 21/2/06 at 06:40 PM |
Ill try and post a pic of mine tonight.
but basically its 3 laser cut pedals with welded eyes which you have a metal crush tube which inserts into them.
You also get the brackets to attach them to the chassis and the actual pedal faces with a threaded rod welded to it so you can adjust them for
height.
also i specified a balance bar so the brake has the correct size whole cut in it to accept the balance bar tube.
tbh i wasnt too impressed with the pedal faces, seem a little small to me(?) but i can always make some new ones if i find i dont like them.
flak monkey
Sorry I cant help, but I have a related question, apologies if its a bit of a hijack, but hopefully whoever knows your answer, can answer my question
too...
Can anyone give me the basic dimensions for the GTS pedals for a tandem mastercylinder? Ie critical lengths etc. I think the twin m/c version
dimensions would be OK if no-one has the tandem ones...
[Edited on 21/2/06 by flak monkey]
Sera
http://www.motosera.com
jay taylor
posted on 21/2/06 at 06:45 PM |
that would be great if you could gav cheers![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
Gav
posted on 21/2/06 at 09:43 PM |
ok heres the pic, ive put a 300mm ruler at the top so it may be of some help to you david. if you want precise measurement just copy that image and
mark out what you need and ill measure it up for you.
[Edited on 21/2/06 by Gav]
flak monkey
posted on 21/2/06 at 09:52 PM |
Cheers Gav,
Bit of a stupid question probably....which is which? Top accelerator, middle brake, bottom clutch?
Pivots look in stange places thats all!?
Will mark up the dimensions I need, and email you the pic. Think I can work some out from that though.
Thanks very much indeed,
Sera
Gav
posted on 21/2/06 at 09:58 PM |
middle is definalty brake, i think the bottom is accelerator and top clutch, will have to see when i attach them
The brackets to attach it to the chassis are different lengths to offset the pivots so you can get the bolts through, which makes the pedals all the
same height, although im still missing the brake bracket.
But i think i might make a proper pedal box rather than just attaching them straight to the chassis.
Triton
posted on 21/2/06 at 10:54 PM |
Top one is the clutch..middle is the brake then bottom is go faster pedal
www.tritonraceseats.com
www.hairyhedgehog.com
Gav
posted on 22/2/06 at 09:10 AM |
wahoo two smartie points for me then ![](/images//smilies/bigsmile.gif)
jay taylor
posted on 22/2/06 at 06:09 PM |
cheers gav thanks for your help![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
