Author: Subject: Seat mounting
dutchsuperseven
Builder
Posts 105
Registered 28/2/03
Location Born, Holland
Member Is Offline
Photo Archive Go!
Building: Locost-clone, powered by zetec 1.8, sierra type N9
posted on 10/3/03 at 12:15 PM Reply With Quote
Seat mounting
Is it o.k. to mount the seats to the bottom alloy sheet in the pass.area, or do they have to be mounted to the chassis. R.C mounted them to the floor is his book.
JohnFol
posted on 10/3/03 at 01:19 PM Reply With Quote
I doubt Ali would be strong enough. I have not made the seat mounts yet, but I aim to either use the side rails, or to add some across the width
Simon
posted on 10/3/03 at 01:41 PM Reply With Quote
My floor is 16swg mild steel fully seam welded, but for the seating I still made up some 1" sq mountings for the seats.
Basically, two 1" square cross pieces for each seat (one for each front and rear mountings) with 1/8th" plate drilled for bolts welded to 1" sq.
Drawing in photo archive.
Hope it helps
Simon
dutchsuperseven
Builder
Posts 105
Registered 28/2/03
Member Is Offline
Photo Archive Go!
posted on 18/3/03 at 12:00 PM Reply With Quote
Seat mounting
I saw in a pic on a dax-site that they only have a alloy panel on which the seat(bench) is mounted. My foor is made out of 2mm alloy. So this should be OK?
posted on 18/3/03 at 12:34 PM Reply With Quote
Surely this depends on the seat!
If you are fitting a classy seat with runners, etc. then you will need to reinforce the floor in some way (cross-members, or whatever).
On the other hand, if you are fitting a fixed seat that's resting against the back panel then it needs no more than something to stop it sliding about - no matter where you're hit, the seat will play no part in your protection.
DJ
