Author: Subject: NOS'd kitcars
omega0684
posted on 4/3/06 at 10:59 PM Reply With Quote
NOS'd kitcars
good evening gents, a late evening at that.....
i was just thinking,
has anyone on here ever built a kit car that uses NOS for that little bit extra power,(i dont want to sound like a little rude boy, as im not planning on putting base bombs and a neon kit on my DAX) i would think that the answer is most probably no but i would like to hear your thoughts on NOSing pintos, duretecs and other engines. what are the adv/dis-adv and other mods that would be needed etc im sure that you guys can think of more stuff than i can, so allow those brains to work overtime on this thread.
ATB Alex
Wadders
posted on 4/3/06 at 11:08 PM Reply With Quote
All the info you need to build your own system
http://www.diy-nitrous.fsnet.co.uk/co2-nitrous-bottles-tanks.htm
indykid
i know carnut for sure runs 40-50 wet nos on his blackbird iirc engine. he was having problems keeping the bottle cool when we went drag racing last summer
i don't know of anyone with cecs and nos, but i'm sure there'll be someone.
tom
bob
posted on 4/3/06 at 11:22 PM Reply With Quote
Hicost experimented with NOS on his cossie turbo, should be some pics of the fitment in his archive.
Simon
posted on 4/3/06 at 11:26 PM Reply With Quote
Bob,
I don't think he ever used it though!
http://www.locostbuilders.co.uk/viewthread.php?tid=4478
Unless there's something we aren't being told
I have thought about it, but I have a load of other jobs that need doing before I start playing with the car too much!
Simon
[Edited on 4/3/06 by Simon]
froggy
posted on 4/3/06 at 11:38 PM Reply With Quote
i had a plate system on a 4barrell carbed rover a few years ago which i used 50hp jets in . on a 4 cyl thats about the limit before you need some form of delivery control which can be done by moving the bottle away from the motor etc. ive still got my kit so its good value once youve bought it as you can take it off easily enough but budget on around a grand for a decent system and £12 per pound for refills if you can find anyone to sell it to you good fun though but a great way of finding weak links in the transmission, i knacked a perfectly good box and clutch trying 100hp jets in my old v8 avenger
emsfactory
posted on 5/3/06 at 02:18 AM Reply With Quote
What is a base bomb?
gingerprince
posted on 5/3/06 at 08:00 AM Reply With Quote
May be worth speaking to the seller of this car: -
Link
MK Indy (BEC) with NOS.
omega0684
posted on 5/3/06 at 09:26 AM Reply With Quote
a base bomb is a sub-woofer/base box, big fat dirty speaker that make it as if the jolly green giant is coming down the road,
ATB ALex
[Edited on 5/3/06 by omega0684]
cornishrob
posted on 5/3/06 at 10:36 AM Reply With Quote
ah good old N2O
Indykid, why would you want to keep the bottle cold?
Omega0684. Speak to wizards of nos (dodgy name i know) but they are the leading force of all things niterous in the UK.
Dont be tempted by cheaper american kits as they are useless for UK use. there standards dont qualify here so its legal to import the bottle, its legal to fit it and run it but its not legal to refil it.
Id personally want some form of control on the system so that when it comes on it gently brings the system up to its full potential. otherwise the resulting jolt to the engine and transmission is more likely to break something.
I will be using niterous on my car when its finished. just for the added scare factor.
froggy
posted on 5/3/06 at 04:35 PM Reply With Quote
im waiting for someonr to come up with a cheap digital controller before i use my system again as they are around 400 quid at the moment .wont be long beforw someone biulds one that uses a dedicated lambda sensor and automatically controls flow and afr
stevebubs
posted on 5/3/06 at 04:45 PM Reply With Quote
http://megasquirt.sourceforge.net/extra/nitrous.html
http://megasquirt.sourceforge.net/extra/afrmap.html
[Edited on 5/3/06 by stevebubs]
indykid
posted on 5/3/06 at 04:52 PM Reply With Quote
don't know exactly, but i'd assume because as the temperature increases, the liquid nitrous will become gaseous. if you inject liquid nitrous, as it expands and boils, it cools the inlet charge. gaseous nitrous won't to the same extent.
i supppose also because there is a limit to the pressure the bottle can take, and as the temp increases, so will the pressure.
i'm no expert, and this is speculation. all i know is mark had wet towels draped round the bottle for most of the meeting. the bottle is in the passenger footwell, and the panelling is ali. with the sun, it was a bloody warm day!
hth
Wadders
posted on 5/3/06 at 04:59 PM Reply With Quote
This link delves into bottle temps.
http://www.diy-nitrous.fsnet.co.uk/nitrous-oxide-system-fitting.htmurl]http://www.diy-nitrous.fsnet.co.uk/nitrous-oxide-system-fitting .htm
http://www.diy-nitrous.fsnet.co.uk/nitrous-oxide-system-fitting.htmurl]http://www.diy-nitrous.fsnet.co.uk/nitrous-oxide-system-fitting .htm[/url]
[Edited on 5/3/06 by Wadders]
Gav
posted on 5/3/06 at 08:42 PM Reply With Quote
presumably he didnt have a pressure safety release valve and it was to stop the bottle exploding ?!?
omega0684
posted on 5/3/06 at 10:42 PM Reply With Quote
can you put NOS on a carb'd car?
Simon
posted on 5/3/06 at 10:46 PM Reply With Quote
Yeah - see Froggy's post above
Simon
Wadders
posted on 5/3/06 at 11:04 PM Reply With Quote
Aaaaaagh! read the link, all of it! you can NOS your lawnmower if thats what tickles yer fancy.
ChrisGamlin
posted on 8/3/06 at 10:33 AM Reply With Quote
One thing to check out before you do it, if your car is still going to be used on the road check what the insurance will be like. It may be different now but I remember about 3 years ago when someone on the Yahoo BEC list put NOS on his Megablade, hardly any of the kit car manufacturers would touch it. In the end I think he had to virtually take it all off (not just turn the bottle off) for road use to get reasonably priced insurance, and bolt it all back on for drag runs etc.
NS Dev
posted on 8/3/06 at 12:03 PM Reply With Quote
Read through a few old issues of CCC mag from around 1995, 96 and 97.
Dave Walker (Emerald Cams, M3D) did some work with Karl on programmable NOS on their old MK1 golf GTI.
Got it working well with mapped NOS, but then made a small cockup where the system didn't ramp down and dumped 100hp worth in at 1500revs and broke the pistons.
A chap I used to know ran a Jeep Cherokee as a tow vehicle for his racer. It was the 4 ltr petrol and he stuck a thumping great turbo on it with nitrous assist (full throttle switched the nitrous in once armed, then a preset boost level switched it back out again)
Could beat pretty much anything off the lights in normal driving.................and that was with an escort cossie on the trailer on the back!!! Great for making fun of chavved corsas at the time!
