Author: Subject: Sierra Front Hubs
ProjectX
posted on 8/3/06 at 10:57 PM Reply With Quote
Sierra Front Hubs
Hi all. Can anyone help with their vast experience?
If using front sierra hub uprights is it better to use:
  1. Top mushroom adaptor
  2. Weld ball joint plate to top of strut top and fit a joint to it
Also what bottom ball joint is suitable for lower wishbone fitting that fits in sierra strut?
Thanks J
billy
posted on 8/3/06 at 11:06 PM Reply With Quote
the adapter seems to work fine
luego-lo-cost finished,vauxhall 16v 2.0,twin 45s de-dion rear set up
quattromike
posted on 9/3/06 at 12:27 AM Reply With Quote
I think the general consensus is that the sierra upright is not totaly suitable for welding to, so mushroom insert is an easier option
Mike
smart51
posted on 9/3/06 at 08:18 AM Reply With Quote
I can't see a problem witha mushroom insert. Why make life harder for yourself trying to weld steel to cast iron?
Taz Surfleet
posted on 9/3/06 at 09:42 AM Reply With Quote
MK's mushroom has the hole offset which allows ajustment of castor etc
posted on 9/3/06 at 10:58 AM Reply With Quote
This point has been covered a good few times -- offset mushroom don't give way of adjusting caster. That is determined by the position of the ball joints -- ie wishbones.
They do however allow the king oin inclination to be adjusted independant of camber adjustment.
ProjectX
posted on 9/3/06 at 08:18 PM Reply With Quote
Ok thanks all for your thoughts etc
J
quattromike
posted on 9/3/06 at 09:50 PM Reply With Quote
I made my own
Made my own mushroom insert
And I'm chuffed with it too
front upright with insert
