brashhighlander
posted on 24/3/06 at 02:23 PM |
Diff Bearing Housing
Hi Folks
I had a bit of a silly moment last night and broke one of the teeth bits off the diff bearing housing. I was trying to remove the oil seal.
Can anyone tell me if this matters? I am using the push in type drive shafts so I don't think this is a problem. If I need to replace it does
anybody know where to get another one and how to remove the broken one.
Jim
NS Dev
posted on 24/3/06 at 02:45 PM |
nah, one broken one will do no harm. They are there to unscrew the housing with, there's a Ford special tool that engages with them and unscrews
the housing.
Vauxhall do just the same on thir FWD boxes, I just use some flat bar through the teeth to unscrew them but this occasionally breaks one off, no need
to panic.
brashhighlander
posted on 24/3/06 at 02:53 PM |
Thats what I thought, but I just wanted to make sure.
