Author: Subject: Flow coat question
RazMan
posted on 29/3/06 at 08:00 AM Reply With Quote
Flow coat question
Having finished some mods to my fibreglass rear section I want to re-apply the black flow coat (on the inside surface) to match the rest of the bodywork.
Is flow coat just black pigment mixed with resin or is it not that simple?
Once mixed, can I apply it by brush?
Raz
bernie955
posted on 29/3/06 at 08:06 AM Reply With Quote
I thought flow-coating was a technique for putting the final colour coats on a panel to reduce the amount of orange peel and, therefore, buffing/polishing.
bernie955
posted on 29/3/06 at 08:07 AM Reply With Quote
You probably mean gelcoat.
RazMan
posted on 29/3/06 at 08:11 AM Reply With Quote
Gel coat is surely for the outer surface?
AFAIK flow coat is to smooth out the inside and prevent light penetration.
It has a slightly waxy finish so I suspect there is an special additive to achieve this.
Raz
Triton
posted on 29/3/06 at 08:19 AM Reply With Quote
Raz,
Flowcoat is gelcoat with added goo to take away the stickyness.
I use gelcoat with a dash of resin and wax solution then brush it on but make sure you flat down the surface first to remove any high spots and sharp bits.
Mark
www.tritonraceseats.com
www.hairyhedgehog.com
Triton
posted on 29/3/06 at 08:20 AM Reply With Quote
Flowcoat is designed to water proof the matt surface.
RazMan
posted on 29/3/06 at 08:25 AM Reply With Quote
Thanks Mark - exactly the info I need
I have just found a local supplier who does a ready mixed flow coat which will be easier for me to use. I didn't realise that gelcoat doesn't go off when exposed to air - the additive apparently forces it to cure completely
Raz
Triton
posted on 29/3/06 at 08:28 AM Reply With Quote
No worries, gel coat will go off it just takes ages if exposed to the atmos..my jeans and boots are crusted in the stuff....
Avoneer
posted on 29/3/06 at 11:03 AM Reply With Quote
Hugh Paterson
posted on 29/3/06 at 09:13 PM Reply With Quote
Ah the wonders of peel ply or even cheapo acetate sheet!
