chrsgrain
posted on 31/3/06 at 02:26 PM |
Polo radiator question
Hi all,
trying to get the cooling system sorted - have gone for a polo rad. Does anyone know which fan thermostat (if tha's what it is!) goes in the
large hole in the back of the rad??
Chris
ned
posted on 31/3/06 at 02:30 PM |
I got mine from mac1, mnr also do one to fit and i then found an old one in a box of bits that came from a nova orother gm originally that is also the
same fitment!
Ned.
beware, I've got yellow skin
RazMan
posted on 31/3/06 at 04:41 PM |
That's a thermal switch for the fan isn't it?
Raz
Flat Pack
posted on 31/3/06 at 04:47 PM |
Yeap its the fan switch, M22 x 1.5 thread I think.
Simon
posted on 31/3/06 at 06:57 PM |
They're also used in Sierras. I got an 82 degree one from a Cossie.
Simon
Simon
Simon
NS Dev
posted on 1/4/06 at 12:17 AM |
yep and as Ned says, GM too. Astra, cavalier, calibra etc etc the choice is yours.
Chazzy
posted on 1/4/06 at 08:33 AM |
some peugots i think, ask your local motor factor, match the thread then choose the temp you want.
Chas
chrsgrain
posted on 1/4/06 at 11:44 AM |
Got one!
Thanks for the advice - the M22 by 1.5 is right - went to the motor factors to pick up the hoses I'd ordered earlier, and picked one out of the
catalogue - the M22 by 1.5 is used in a vast array of cars - so as per the advice I picked the temp I wanted and got one from stock - think its an
Opel one as fitted to lots of Atras - also picked one with exposed terminals so if any soldering is needed it will be easier...
Thanks for all the help!
Chris
