Paul (Notts)
posted on 2/4/06 at 12:15 PM |
alternative rear caliper
Anyone any experiance or views on these alternative rear calipersImage deleted by owner
mookaloid
posted on 2/4/06 at 12:59 PM |
well the alloy won't rust......
liam.mccaffrey
posted on 2/4/06 at 02:04 PM |
I bought thembut havn't fitted them yet
think someone said they were from a mk2 golf, or at least you can use the handbrake cable from a mk2 golf. VAG pretty sure though. There was a
detailed thread on it a while back
Build Blog
Build Photo Album
MikeR
posted on 2/4/06 at 02:07 PM |
thr rally design ones i think.
vw golf springs to mind as the source. sure its been discussed before when tald (?) looked at supplying them.
MikeR
posted on 2/4/06 at 02:08 PM |
damn, must learn how to type faster when eating ice cream !!!!
uklee70
posted on 2/4/06 at 02:35 PM |
I have a pair for sale un used
As they don't fit under 13" rims
u2u me with an offer
Lee
omega0684
posted on 2/4/06 at 02:37 PM |
yes this has been discussed before, have a lookie in the search section, but to save you the time, they are based on the mk2 golf, made of Ali for
light weight, weighs about a kilo less than the std sierra rear caliper, and as mentioned above it wont rust. im thinking of getting some for my DAX,
check out rally design for the full spec but i think they will take rear solids, vented and drilled up to 14mm wide(dont quote me, it may be 12mm)
hope this helps
ALex
p.s i think it can be used as a direct replacement for the sierra rear as well
Flat Pack
posted on 2/4/06 at 07:34 PM |
I've got the Rally Design kit with these in, they're on the car but the car isn't near enough finished to see how well they work
yet.
They're a bit of a fiddle to fit, you have to machine the hubs down to take the discs they use (Escort fronts possibly, not entirely sure). The
main struggle I had was actually getting it all together, the bell on the discs is so deep you have to remove the caliper carrier to fit the disc and
with my uprights I can't do that with the hub carrier in place. Cue a big song and dance with putting bits on so I can fit other bits then
taking them off again to fit still more bits, putting them back on again and so on until finally its all in one piece. Hope I don't have to
change the discs too soon...
