Sean
posted on 9/4/06 at 06:14 PM |
Ball joint for Triumph uprights??
I am pondering making up a set of front upper wishbones that fit in place of the unattractive Triumph ones. I found the part number for the ball
joint/ track rod on the caterham site QR 1118s a track rod end, which will locate in a threaded tube. Can anyone confirm that this is indeed the
correct part.
zilspeed
posted on 9/4/06 at 06:32 PM |
Is it a Robin Hood you have (triumph wishbones) ?
Sean
posted on 9/4/06 at 09:35 PM |
no I am just doing some mods to my phaeton
Chippy
posted on 9/4/06 at 11:19 PM |
Funny, my Dutton Melos used the escort
struts, which Dutton cut down, and welded to take the (I think), Maxi ball joint. What year was your Pheaton? Mine was 1984. Regards Chippy.
Sean
posted on 10/4/06 at 07:10 AM |
Mine is all triumph front end, but dutton changed to ford later on, hence your set up. The early caterhams used the same triumph uprights so its that
top ball joint I need to check.
