planetester
posted on 16/4/06 at 07:42 PM |
Crush tubes (again)
How should crush tubes fit into the poly bushes, as supplied my front wishbones need the tubes forcing in in the vice, yet the rears are a good hand
push fit,
I think the tubing used in my wishbones & trailing arms is slightly differant dia so the fronts are compressing the poly bushes more than the
rears,
should I take a few thou off the front tubes to let them fit by hand
Chippy
posted on 16/4/06 at 11:00 PM |
When i fitted mine they all had to be pushed in by using a vice. I would think that it would be preferable to have them tight, rather than slack. Only
my opinion of course, no hard facts to back it up. Regards, Chippy
ReMan
posted on 16/4/06 at 11:30 PM |
I used upper and lower wishbones from 2 different mfrs.
On one the tubes were really tight fit and could only be pushed in using the vice.
The other were really really tight fit and could only be pushed in using the vice.
www.plusnine.co.uk
