slopecombat
posted on 21/4/06 at 09:16 PM |
MadSorley 73562+-
It will be a long long way ...
Somebody has done a locost with an arc welder ?
RichardK
posted on 21/4/06 at 09:19 PM |
Is this another "What is this question?"
robinbastd
posted on 21/4/06 at 09:20 PM |
I don't think you're following those plans closely enough.
http://smuttygifts.com/
Mr G
posted on 21/4/06 at 09:28 PM |
I think its been assimilated by the borg
Mark Allanson
posted on 21/4/06 at 09:39 PM |
resistance is fertile!
slopecombat
posted on 21/4/06 at 10:48 PM |
I've burned just 30 arcs but ...
I think is almost impossible to do it with the 25x25x1.5 mm RHS tube. I've been trying with 1.5 mm arcs and I'm very disappointed, the
results are worse than the 2mm ones.
I'll do it with 25x25x2 mm tube (the difference of the weight is not important) and give me a 0.5 mm of margin over de 1.5 mm penetration of a
good weld.
I'll weld the chasis with my arc welder, no doubts, but... I'll feel better if anybody has done this before !
gazza285
posted on 21/4/06 at 11:10 PM |
I've done a lot of mine with 2.5mm rods, you can't hang around though or else the pool drops out of the tube. It can be done though.
CommanderAce
posted on 22/4/06 at 08:36 AM |
but you forget, the Borg strive for perfection!
Roads? Where we're going we don't need roads!
James
posted on 24/4/06 at 11:30 AM |
I think your mistake was trying to weld that piece of painted wood on the middle of it!
- Muhammad Ali
posted on 24/4/06 at 12:21 PM |
I knew there were a few mistakes in the book!
slopecombat
posted on 25/4/06 at 11:47 PM |
Mista
There are mistakes in the book, pdfs, ... everywhere !!!
