Jasper
posted on 8/4/03 at 11:53 AM |
Earth through ali
Is it ok to earth onto bolts onto ali panels rivitted to the chassis, ie does ali provide as good an earth as the steel chassis?
StuartA
posted on 8/4/03 at 12:02 PM |
This is what we have done with our fuel pump and continuity seems to be fine. Fuel pump bolted to ali mount, earthed to same mount via a rivet. Ali
mount then riveted to chassis. Checked continuity to one of the wheel rims and seemed to be a good circuit. Not sure on the relative conductivity of
ali versus steel, but I'm pretty sure that all metal conducts so would have thought it would be fine.
Of course I might be talking out of my ear, in which case someone correct me and we will have to redo our fuel pump! ![](/images//smilies/tongue.gif)
posted on 8/4/03 at 12:10 PM |
Ali is a far better conductor than steel, not quite as good as copper.
Earth returns through the ali will be fine, with one reservation: aluminium oxide is an excellent insulator, so keeping a good connection may be a
problem. However, it's not a major issue - just take care to keep water out of the joint.
Jasper
posted on 8/4/03 at 12:45 PM |
Cheers chaps
StuartA
posted on 8/4/03 at 03:57 PM |
I guess a blob of silicon sealant over the top of the rivet might be in order then ![](/images//smilies/wink.gif)
theconrodkid
posted on 8/4/03 at 04:23 PM |
i,d put an earth lead on just in case
who cares who wins
pass the pork pies
stephen_gusterson
posted on 8/4/03 at 06:22 PM |
just cos something is in vague contact - ie a rivet against an alu sheet - does not mena its a good consistent long term earth.
If its drawing several amps, or important, I would earth bong the panel by more positive means.
atb
steve
Mix
posted on 9/4/03 at 08:09 AM |
It is true that alloy will provide a suitable earth path, however it is also a fact that dissimilar metals in contact and in the presence of an
electrolyte, (water) will set up galvanic action, (they act like a battery). This induces corrosion, the products of which will not conduct. Wherever
possible alloy should be insulated from steel using sealant. IMHO the best method would be to bond the components electrically to a steel chassis
member.
Mick
merkurman
posted on 19/4/03 at 11:19 PM |
a good fix might be to scuff arounf the rivet and put a spot of solder on it. also anywhere you have a screw for a ground make sure to put on silicon
dielectric grease on it. (good old petroleum jelly works too)
nick
1962 fairlane with a 200" six and T5 5spd, shaved trim air ride, t3/t4 turbo and soon to be EFI
-- looking to put a offy tripower intake on soon
