Author: Subject: bolt sizes for seat mounting?
posted on 8/5/06 at 10:09 PM Reply With Quote
Just looking at mounting my Intatrim seats into the Indy. I'm planning on bolting them directly to the floor through the steel straps welded into the chassis. Plan is to use dome cap heads witha penny washers through the base of the seats, then penny whashers and nylocs under the floor.
What size to use - is M6 too small? or should I use M8?
Comments!
Nick
MikeR
posted on 8/5/06 at 10:16 PM Reply With Quote
why not but the dome heads under the floor? less to get caught on something.
RazMan
posted on 8/5/06 at 10:22 PM Reply With Quote
M8 with penny washers should do the trick
Raz
indykid
posted on 8/5/06 at 10:34 PM Reply With Quote
the threaded bosses on most seats are m8, so i figured that must be a good size.
m6 does seem a bit weedy.
tom
shortie
posted on 9/5/06 at 07:11 AM Reply With Quote
Nick,
Just one thing I realized when I came to bolt my seats directly to the floor in the Indy, are you sure the steel straps are in the correct place?!
Mine were not as I needed the seat right back against the bulkhead and the straps were in completely the wrong place. They may have changed the positioning of the straps now but worth checking!
HTH,
Rich.
Bryan Sears
posted on 9/5/06 at 11:25 AM Reply With Quote
I got my seat runners from Midland Wheels good service and not expensive.
When you sit in the car this way you can adjust the seat to make yourself comfortable. I have long legs so I need the seat right back to get in and out.
My wife has short legs so I can keep up the pretence that I will let her drive.
scoop
posted on 9/5/06 at 03:28 PM Reply With Quote
SVA manual says "at least" m8 of 8.8 strength
posted on 9/5/06 at 06:41 PM Reply With Quote
Shortie - straps are in the wrong place for the driver (that'll be me) but would probably be Ok for the passenger side.
I figured M8 would be about right, but that means going to the nut and bolt man again
Opinion seems very mixed on the quality of the seat runners available, but I can't really see any other practical option for the drivers seat
indykid
posted on 9/5/06 at 10:53 PM Reply With Quote
for the passenger side on mine, i used 1" rhs, drilled up for caphead bolts into the bottom of the seats, and down to put captive bolts through the straps.
put the captive bolts in first, then bolt the rhs to the seat. i had runners the first time on the drivers seat, but will probably go with rhs this time round.
give endless scope for seat position fore/aft.
tom
Liam
posted on 9/5/06 at 11:23 PM Reply With Quote
Is that only if the seatbelts are attached to the seats?? Only, if the seatbelts are attached to the chassis it shouldn't really matter what the seats are attached with. The book locost has seat squabs that aren't attached at all doesn't it?
Liam
indykid
posted on 10/5/06 at 12:33 AM Reply With Quote
does it not also have upper seatbelt mountings that are too low to satisfy sva, and bugger all castor?
squabs are a different animal to a one piece seat though. squabs by their very nature are well fitted. if you had scatter cushions, i'd think they'd pull you up too.
tom
posted on 10/5/06 at 09:41 AM Reply With Quote
Tom - when you say "captive bolts do you mean something other than a normal hex head bolt?
