Winston Todge
posted on 15/5/06 at 12:19 PM |
Airfields around Bristol?
Just looking for places to test the car at the limit (not that its built yet...) in a safe environment.
Any airfield track days like Elvington down the south west that anyone knows of?
I know Castle Combe's on my doorstep but fairly pricey and not huge runoff...
Chris.
Bryan Sears
posted on 15/5/06 at 01:02 PM |
Castle Combe is meant to be one of the best tracks in the country but you are right it needs a lot of balls. What about Pembray in South Wales if you
make a mistake you have all the sea to run off into. Sounds like you have nearly finished.
Thanks for hosting the instruction manual it has been a great help to me.
wheelfelloff
posted on 15/5/06 at 02:08 PM |
Chris
They do track days at RAF Hullavington which is only about 30 miles from Bristol and a nice trip up the M4. Try
http://www.motorsport-events.co.uk/hullavington_airfield_track.htm for this years info. I'm a bit out of date but they also used to do them at
RAF Kemble which is only about 7 miles further on the same road.
Best regards Keith
matt_claydon
posted on 15/5/06 at 02:38 PM |
Motorsport Events also run days at Keevil airfield which is not far from Bristol either.
Ian Pearson
posted on 15/5/06 at 04:13 PM |
I believe you can use the runway at Henstridge airfield for a small fee when they are not flying. Might be a bit far for you. Henstridge is about
midway between Shaftesbury and Yeovil.
Guinness
posted on 15/5/06 at 04:32 PM |
Dude, if your avatar is correct "Present State" I would have thought the handling would be pretty static
Across the bridge
Llandow
Llandow Circuit
Llandow
Nr. Cowbridge
Vale of Glamorgan
Tel: 01446 796460
HTH
Mike
