davepro
posted on 21/5/06 at 08:07 AM |
Cleaning to Diff
Hi Guys,
Is there an easy way of cleaning up my old Sierra diff, or is it just a matter a wire wheel and lots of effort.
Dave
posted on 21/5/06 at 08:15 AM |
Wire brushes, dremel, screwdriver, parafin and loads of elbow grease. But it is worth the effort in the end.
Phil
mark chandler
posted on 21/5/06 at 08:55 AM |
Stick it in a bucket of path cleaner, let it fizzel overnight and pressure wash the next day.
Avoneer
posted on 21/5/06 at 09:11 AM |
Best and easiest thing after going the oven cleaner and all the other routes is the following:
Spray on brake cleaner and a wire brush
You'll have it clean in 10 minutes ready for painting.
Liberally keep spraying all over and rubbing with the wire brush.
Then one final spray to clean all the dust/debris off.
You may go through 2 aerosol bottles though.
But it works.
Pat...
Marlon
posted on 21/5/06 at 10:06 AM |
I used ordinary paint thinners put on with a paint brush and gently worked in then blew off with an air compressor. Nice and clean!
Band Anyone?
Linky to SWMBO 's band
Linky to Brother in laws band
MKoc 1081
locoboy
posted on 21/5/06 at 02:36 PM |
heres what mine looked like after a pressure wash with steam and a good going over with Gunk degreaser and a good old scrape with a screwdriver to get
into the little nooks and crannies.
http://www.locostbuilders.co.uk/viewthread.php?tid=40207
Locoboy
Simon
posted on 21/5/06 at 03:07 PM |
I made some rubber plugs to cover all holes, and chucked it in the bead blaster.
Then paint
Simon
BKLOCO
posted on 21/5/06 at 03:56 PM |
sand blast attachment on a pressure washer did it for me
Make sure you seal all your orifi though
[Edited on 21-5-06 by BKLOCO]
