davepro
posted on 24/5/06 at 04:38 PM |
Servo or no servo
Hi Guys
I'm building a locost and would like advise on whether I should fit a brake servo or go without one.
Dave
Dave Prouten
flak monkey
posted on 24/5/06 at 04:39 PM |
No servo
Sera
http://www.motosera.com
posted on 24/5/06 at 04:40 PM |
You dont need the servo. The car is light enough and theres no room for the servo.
If your going down the BEC road theres no vacumm to pull the servo.
[Edited on 24/5/06 by coozer]
donut
posted on 24/5/06 at 05:30 PM |
NO
matt.c
posted on 24/5/06 at 05:39 PM |
Just press harder
P.s flak monkey, great avatar
ditchlewis
posted on 24/5/06 at 06:15 PM |
I also was worried about no servo but these cars are so light they dont need one. if you had one you would be locking up the wheels all the
time
ditch
smac
posted on 24/5/06 at 06:46 PM |
Mine has a servo but I disconnected the vacuum feed when I fitted twin carbs. Someone put my mind at rest that this is ok.
natehall
posted on 24/5/06 at 07:05 PM |
should be - the vacuum just helps to feed the brake master cylinders - had one fail in my sierra - and boy was it hard to stop
Simon
posted on 24/5/06 at 07:12 PM |
No. Mine weighs about 800 kgs and I manage without one!
Simon
JB
posted on 24/5/06 at 08:07 PM |
Servo
Do not fit a servo.
Servos are extra complication, something else to find room for, more pipes and reduce the vital pedal feed back.
If you have the correct pedal leverage, master cylinders and calipers you will stop with out excessive leg work.
John
smart51
posted on 24/5/06 at 08:34 PM |
I can lock the wheels up at will without a servo. the pedal is very firm compared with the light clutch of a BEC but the brakes are not as heavy as
my old Saxo. You don't need a servo.
posted on 24/5/06 at 11:49 PM |
Servos don't improve the brakes, they just make the pedal easier to press. As said earlier if your pedal ratio is good it will be fine without
power assistance.
