New Topic New Reply
Author: Subject: Chassis Width
stig2
posted on 25/5/06 at 07:39 AM Reply With Quote
Chassis Width
By how much should I widen the chassis if I am using a Sierra for donor parts?
Avoneer
posted on 25/5/06 at 07:45 AM Reply With Quote
Nowt - unless you are anorexically challenged.
You'll just need wider rear arches.
Pat...
James
posted on 25/5/06 at 09:27 AM Reply With Quote
Agreed.
Widening it can only make you life harder.... I speak from experience!
James
wilkingj
posted on 25/5/06 at 10:19 AM Reply With Quote
Use Wider Back wings to cover it up?
Best Regards
Geoff
http://www.v8viento.co.uk
smart51
posted on 25/5/06 at 11:07 AM Reply With Quote
if you are going to have a wider axle then you might as well have a wider chassis. You will have a less exposed right elbow or more room between you and a passenger. Are there plans for a 4" wider chassis or is it just a +442? I'm sure it's worth the extra effort.
posted on 25/5/06 at 11:53 AM Reply With Quote
Draw it out on your baseboard with the seating area 4" wider and just extend the J1 and J2 and the D1 and D2 till they meet the side rails, then make all the back 4" wider.
t.j.
posted on 25/5/06 at 12:16 PM Reply With Quote
I'm using the sierra track at the rear 151 cm. planning with 195/50 r15 it will be about 173 cm.
As i'm someone with at lot of muscles i'm want the place to sit 5 cm extra room.
So i planning to extended the upper rail which comes from the scuttle, this will result in more room at my back. like HKT, VM and Donkervoort does. Only problem is that you will get more corners in the rear instead of handy 90degrs
posted on 25/5/06 at 01:19 PM Reply With Quote
Personaly I think the massively wide rear arches look awfull on a 7, especialy from the rear. I would definately go for a 4" wider chassis using either the McSorley plans or the GTS plans (though you have to pay for them).
Simon
posted on 25/5/06 at 08:21 PM Reply With Quote
I added 4" across the width on mine.
Of course, you could always chuck an A Series in the "boot" and do away with the transmission tunnel. Then you could put the wheel in the middle and have 3 1/2' for your muscles
Simon
[Edited on 25/5/06 by Simon]
leto
posted on 12/6/06 at 07:07 AM Reply With Quote
Get the rear wing and the wheels you plan to use. Try on the wings over the wheels till it will look good. Build chassis to fit. A friend of mine actually did this.
“I'm gonna ride around in style
I'm gonna drive everybody wild
'Cause I'll have the only one there is a round”. (J. Cash)
New Topic New Reply
