Author: Subject: Rear lower wishbone measurement...
Winston Todge
posted on 29/5/06 at 10:33 AM Reply With Quote
Could someone with a VortX RT do me a massive favour and measure the distance from the inside mounting face to inside mounting face of the lower two rose joints. The two that attach to the lower rear upright mounts...
I've had two replacements sent through and both of the uprights seem to be too wide. I just want to make sure that the wishbones aren't too narrow.
Thanks,
Chris.
Bryan Sears
posted on 29/5/06 at 10:51 AM Reply With Quote
Hi Chris I asked Marc this he said you have to cut the back part of the thread on the upright to make it fit.
I have had to cut one of mine down to the weld and am now going to tap the thread in the upright to get the bolt to secure properly.
RichieC
posted on 29/5/06 at 11:19 AM Reply With Quote
Yeh same here, I had to cut an amount of each side of the MNR rear upright so that the wishbone would fit.
Dont worry too much about it, a little at a time and jobs a good un
Rgds
Rich
Winston Todge
posted on 29/5/06 at 11:35 AM Reply With Quote
Just got off the phone to Marc. What a pillock I am...
It doesn't seem to mention the fact that the rear upright needs modifying in the Build Manual that I've got, but all is well now!
Rolling chassis by the end of the day, hopefully!
Then bodywork off and up to the Manifold Fabricators...
Thanks again guys,
Chris.
smart51
posted on 29/5/06 at 11:56 AM Reply With Quote
rear upright needs modifying? I didn't mod mine. What have you had to do?
Winston Todge
posted on 29/5/06 at 09:52 PM Reply With Quote
The lower upright mount where the two 1/2 UNF short bolts go needs to be shortened to allow the upright in between the two rose joints on the lower rear wishbone.
All done today and finally got the rear end together.
Chris.
JoaoCaldeira
posted on 29/5/06 at 10:00 PM Reply With Quote
I didn't modify mine... any chance of a pic showing what are you speacking of?
Joao
RichieC
posted on 29/5/06 at 10:07 PM Reply With Quote
Were maybe talking about different parts. I mean the UNF threaded portion on the bottom of the rear upright. It was too wide for the gap between the rear lower bones. I had to cut a few mm off each side to enable the wishbones to fit.
Maybe just a few ones out of tolerance.
Rgds
