Author: Subject: Using a Daihatsu 1991 1300 EFI Automatic
Ben
posted on 17/4/03 at 01:30 PM Reply With Quote
I am in the possesion of a 1991 automatic Daihatsu Charade 1300 which has driven only 56.000 KM (about 40.000 miles) and has a superb engine. However, the coachwork is not so perfect anymore. The car belonged to my mother, who stopped driving it at 85 years of age and I have owned this car now some three years as a second car. The topspead of this little bugger is very satisfactory (180km/hr (real GPS measured speed) and the acceleration is accordingly. I'm planning to use the engine in a Locost. The problem is that I therefore have to mate the engine to a rearwheel transmission. That
means to a Sierra gearbox alike etc. Does anyone have experience with this kind of set up and has anyone done this before? Can anyone give me recommendations about the way to do this and enlighten me about the problems I might encounter.
Ben Majoor
The Netherlands
James
posted on 23/4/03 at 09:49 AM Reply With Quote
You might have more luck posting this in the engine section as a lot of people don't read the manufacturer specific sections.
HTH,
James
ned
posted on 29/4/03 at 10:54 AM Reply With Quote
like james says, try posting in engines or running gear sections.
2 options I can think of would be to either:
a) make up an adaptor plate/bellhousing to fit to a ford/sierra box
b)try and see if the engine by any chance shares the block with any van that might have a box for rwd that will bolt onto it.
good luck.
beware, I've got yellow skin
ned
posted on 29/4/03 at 10:55 AM Reply With Quote
just noticed its a 1300 engine, ignore option b)!
posted on 4/5/03 at 10:01 PM Reply With Quote
You could look at the Hi-jet van, that was rear or 4 wheel drive.
yours, Pete.
