hector
posted on 9/6/06 at 06:25 AM |
speedo's
What would be the best one to buy? I am needing my gauges now, I need to get a speedo that can be calibrated ,and does everyone take the pick up point
for sensor from the propshaft? or are there any other alternatives?
cheers colin
donut
posted on 9/6/06 at 07:13 AM |
Do Not Buy Telemetrix Guages as the speedo's are cr*p!
cryoman1965
posted on 9/6/06 at 11:53 AM |
I am using an Acewell 3150 digital gauge. Speedo picks up from rear drive shaft. Revs from HT Lead.
cryoman1965
posted on 9/6/06 at 11:56 AM |
Have a look here.
http://www.16vminiclub.com/forums/viewtopic.php?t=5148&postdays=0&postorder=asc&start=0
[Edited on 9/6/06 by cryoman1965]
hector
posted on 9/6/06 at 05:09 PM |
cheers chaps. those digital jobbies look good but dont you need a illumination lamp to tell of the handbrake/fluid level, how do you get around this?
16vmini
posted on 10/6/06 at 12:01 PM |
email me if you want a dash info@16vminishop.co.uk (i was the one that sorted the group buy out) can give you a locost builders disscount.
most people use a bright 6 lamp set ??
Matt
http://www.16vminishop.co.uk
atomic
posted on 14/6/06 at 07:20 AM |
Autometer Ultalite's http://www.autometer.com/cat_gaugeop.aspx?sid=11 are very good as are the new SPA Dual range
http://www.spa-uk.co.uk/design/tachometers.asp
John Bonnett
posted on 17/6/06 at 07:41 PM |
I may be missing something here, but why not use a speedometer driven by a cable from your Ford gearbox? If the cable is a problem Speedy Cables will
supply one with the correct ends and they will also calibrate the speedo as well.
John
