andyd
posted on 26/4/03 at 06:26 PM |
Sprocket adaptor play
Anyone using a Fisher Sportscars sprocket adaptor on a blade engine?
Having just coughed up over £7 at our local Honda dealer for the sprocket bolt and washer that we managed to misplace somewhere in the garage, we find
that after fitting it (them?) there is some play in the adaptor. The bolt is done up tight but the splined bit of the adaptor seems to be slightly
too short resulting in free play in the forward/backward direction.
Does this matter at all? I'm worried that because of this it'll allow vibration to start as even with the prop bolted in place the UJ at
the front still allows the play even though the prop overall doesn't have any play. Incidentally putting the original front sprocket back on
and refitting the bolt/washer, the same amount of play is present. However on the bike the chain "wobbles" a small amount anyway so
I'm guessing that it not so much of a problem. But what about on the car where it may vibrate the fillings from our teeth?
locodude
posted on 26/4/03 at 07:25 PM |
If you mean the sprocket can still slide up and down the spline then yes it's a common thing. You need a washer with a 30mm i/d approx 3mm
thick. This will cure it.
andyd
posted on 26/4/03 at 09:47 PM |
Chris,
Do you mean a washer to fit "behind" the adaptor i.e. fitted over the splines first before the adaptor then fit the big washer and bolt to
keep it in place?
If so that size doesn't sound like something that you can get at B&Q. Any clue as to where I may obtain such a thing. I wish I had a
lathe!
[Edited on 26/4/2003 by andyd]
locodude
posted on 27/4/03 at 12:06 AM |
If you put the washer behind the adaptor then you have more room for the locknuts, and yes it's nice to have a lathe. Drilled out sierra hub nut
washers are just the thing!!!
andyd
posted on 27/4/03 at 10:21 AM |
Thanks Chris, I'll have to hunt around to find something like this or maybe get my mate to get one made up via his lathe owning buddies.
ChrisGamlin
posted on 27/4/03 at 11:29 AM |
Andy, make sure you get something to stop that adapter moving though, like Chris says a spacer washer of some sort to remove any slack. I know of one
Locost BEC racer who unbeknown to him, had the same issue (Stuart Taylor forgot to supply the spacer), and the end result was the adapter and prop
breaking the bolt and a lot of damage done by a flailing prop (luckliy no injuries though!)
Chris
andyd
posted on 27/4/03 at 12:34 PM |
Ouch... that's what I was afraid of happening. Definately be sorting this one out.
dodgyroger
posted on 27/4/03 at 06:43 PM |
Andy,
If you source a supplier for that spacer, let me know. I have the same problem but have not got around to sourcing one yet.
Better still, get two and I'll settle up with you
Roger
http://www.dodgyroger.com/locost
andyd
posted on 27/4/03 at 09:12 PM |
No worries Roger, I'll let you know as soon as I have two.
carnut
posted on 27/4/03 at 09:13 PM |
I seem to have a similar problem. When i did the nut up tight the adapter didnt slide up and down but it did seem to have a bit of wobble in it. I
thought that this was normal as it was like that with the sprocket. I am now unsure on wether it is correct or not.
By the way im using a blackbird engine and the adapter is from mk.
Any ideas would be greatly recieved
ChrisGamlin
posted on 27/4/03 at 09:51 PM |
There shouldnt be any movement regardless of engine, should be tight, so I'd give it a check carnut
Chris
carnut
posted on 28/4/03 at 04:18 PM |
cheers, ill take it out and have a closer look. I think that putting a washer in should do the trick.
dodgyroger
posted on 28/4/03 at 09:29 PM |
Better make that 3 spacers Andy
steve faunch
posted on 28/4/03 at 10:09 PM |
Im running a blade powerd car & had the same problem. M.K. supplied me with some shimms problem solved![](/images//smilies/bigsmile.gif)
