Author: Subject: steering shaft query
jimbona
posted on 31/7/06 at 12:51 PM Reply With Quote
Has anyone got a picture of the steering shaft handy?
I dont know where mine is from as I got it off someone but the steering shaft seems too long! - i need to find my camera to be able to take a photo to show people before you ask!
Im referring to the bit between the steering wheel connector (that tends to be trianglar shaped) to the steering rack
John Bonnett
posted on 31/7/06 at 03:44 PM Reply With Quote
It sounds like a Sierra column. This is the one on my Phoenix.
http://i93.photobucket.com/albums/l57/bonnett_2006/phoenix4003Medium.jpg
John
tractorboy
posted on 1/8/06 at 11:05 AM Reply With Quote
if i remember correctly the steering shaft is modified ,as it has a rose joint put on it that bolts into a bracket on the side of the chassis but i have an old chassis so they may well be using a different set up now. cheers scott
jimbona
posted on 6/8/06 at 12:56 PM Reply With Quote
thanks, great photo. Tiger have got back to me, apparently I have the wrong one! Gota send my steering shaft back for them to send the correct one. The one I have is almost 40 inches long! well too long.
Hopefully when the correct one arrives the fittings will become obvious.
