givemethebighammer
| posted on 2/8/06 at 09:47 PM |
Type 9 speedo drive oil leak
How has anyone else stopped the speedo drive from leaking oil when not using it (I have an electronic speedo run from magnets on one of the
driveshafts).
As I understand it, the speedo cable assembly holds the oil seal in place and stops it leaking ?
[Edited on 2/8/06 by givemethebighammer]
NS Dev
| posted on 2/8/06 at 10:04 PM |
not as far as I know, the oil seal is independent of the speedo cable assembly, I was worried about the same thing but i pulled a spare one to bits
and there is nothing to leak other than the seal which presses in.
Just
| posted on 3/8/06 at 07:16 AM |
Just replaced my speedo cable (as it snapped) and there was no oil seal behind it or even any sign of oil behind it - I would be surprised if oil was
leaking out of the speedo drive whole, but if it is a chopped off cable with the inards taken out and the end sealed would do the job.
givemethebighammer
| posted on 3/8/06 at 02:52 PM |
It's not currently leaking, the reason I asked the question is that I have just changed the gearbox. On the old gearbox I bodged up a bung to
make sure it didn't leak. I just felt there might be an easier way of doing it this time. I think the cut off cable with the end sealed up
sounds the best idea.
thanks
NS Dev
| posted on 3/8/06 at 04:01 PM |
Mine is just left with no cable attached, was woried myself but I have done it that way in the past. there is deffo an oil seal in there cos I have
pulled one box apart to check and chenged the seal on another.
givemethebighammer
| posted on 6/8/06 at 07:24 PM |
All done, old cable chopped, insides removed and a lump of epoxy putty forced into the end of it to seal it. I probably don't need it, but I
feel happier with it fitted (I hate the smell of transmission oil and don't want it on my garage floor at any cost !)
thanks
NS Dev
| posted on 8/8/06 at 07:19 AM |
tis certainly stinky stuff! Just be glad you don't have a live axle with a plate LSD in it!! The additive in them smells so much you can smell
it when you have a new sealed (and I mean sealed as in heat sealed shut by ford after filling) cartridge of it in the garage from 20 feet away!
