Author: Subject: Type 9 Gearbox
tri
posted on 10/8/06 at 07:59 PM Reply With Quote
Type 9 Gearbox
Type 9 5 speed gearbox on a pinto.
I am having a problem selecting 1st gear (have to depress slightly as if going into reverse), cannot select 2nd gear. No problems selecting 3,4,5 and reverse. I have a remote gear select. Can anyone offer any suggestions as to what maybe wrong. Any help would be appreciated
Just
posted on 10/8/06 at 09:09 PM Reply With Quote
Is this at any speed? Sounds like the remote may have warn a little or gone off adjustment slightly.
Usual things to check are oil level, clutch adjustment, clutch arm mech and then remote adjustment.
Monkeybasher
posted on 10/8/06 at 09:54 PM Reply With Quote
sounds like the remote to me. Mine did this when the stop bolt(to go into reverse) slackened off.
tri
posted on 11/8/06 at 05:46 AM Reply With Quote
Thanks for the help. I will have a look at that.
Regards,
Tri
