carsonp
posted on 13/8/06 at 03:42 AM |
IRS vs Solid rear with at least 350hp
Im trying to plan out a LSX/T56 in a locost and i cant decide on what type of rear suspension would be best.
My original thought was C4 or C5 vette IRS or something, then i was thinking it its gonna be hard enough as it is to hook with 350hp and almost equal
TQ so maybe a nice strong solid rear would be best (4 link maybe?)
What do you think?
smdl
posted on 13/8/06 at 06:07 AM |
Carson,
Being that this group is UK based, you might have more success with some of the US resources. Try:
Locost North America Yahoo! Group
There is a lot of great information in that group, although most lean towards building Locosts light and nimble instead of with brute performance.
One guy in particular (Ted Saton) has built some interesting V8 powered cars.
Another good option would be the forum at:
Locost USA
Hope this helps.
Shaun
wilkingj
posted on 13/8/06 at 07:49 AM |
I have seen the Luego LV350 Viento Chassis (I have a std Viento), and its braced up much more than the std Viento. Its designed to take the Small
Block Chevvy 5.7Litre 350Bhp Engine. The Std Viento is more or less an overgrown locost, but the LV350 is a fair bit different.
If you are putting 350Bhp in a locost chassis, I would strongly suggest some extra bracing and strengthening.
350Bhp (and the torque) is a lot for a chassis that was originally designed for 100bhp / Crossflow engines.
You will also need Disc brakes all round, and Cosworth ones at the front. You have a lot of extra weight especially at the front end to stop.
Just my 2d worth.
Best Regards
Geoff
http://www.v8viento.co.uk
carsonp
posted on 13/8/06 at 09:08 PM |
Im planning on more bracing and also thicker material for a a lot of it )plus a good cage)
As for brakes it will definitly have disks all around, probably from a C4 or C5 corvette cause im going to use the suspension and wheels from them
(probably)
thanks
